don lord
911 SC brake problem!
I have an 83 911sc which always locks up the front right wheel under heavy braking. I cannot get both fronts to lock up together.
I have tried: checking that the pistons are free in the calipers. renewed the front pads swapped the front wheels side to side. checked the front corner weights are about equal. It beats me, so any ideas as to what might be causing this imbalance in the braking would be welcome!! Don Lord
Don Lord 1983 911SC 1992 968CS |
Max Sluiter
Tire pressures or tire condtion.
Were you in the car for the corner-weighting?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Replace the flexible brake lines, they get clogged over time.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera Last edited by kodioneill; 04-16-2010 at 01:11 PM.. |
don lord
Hi Max,
My wife was in the car + extra ballast to make up to my weight for corner weighting. tyres both good with equal wear. Don
don lord
Hi kodioneill,
Never thought that the flexibles could cause this problem. will change them tomorrow and see if it does the trick. Thanks Don
I'd bet the farm on it! Replace the rears also.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
The only thing that has ever caused that in my SC is corner balance. I know you said you had the front's checked, but if you have any doubts, you can search for "tripod method" here and us that to check your balance front and rear (within an hour or so) for peace of mind.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
I had a problem similar to yours and it was the left caliper not engaging as quickly as the right. At first I thought it was the right caliper that had problems because it would pull to the right; however it was opposite of what I had thought. Maybe they both work but are not working as efficiently as one another. Just a thought.
don lord
Thanks for all the advice guys. Tried the "tripod method" as recommended by Martin Smith to adjust the ride heights on the front end, corrected an imbalance, and it has done the trick. Now braking correctley!!
Thanks Don
