-   -   What is Weber 40IDTP3? (http://forums.pelicanparts.com/porsche-911-technical-forum/162405-what-weber-40idtp3.html)
jchatfield 05-10-2004 01:37 PM
I am rebuilding my Webers and I don't recall the eact part number, but instead of 40IDA3C, which is what I expected, the number started with 40IDTP3.
What is the difference?
Grady Clay 05-10-2004 01:57 PM
The nomenclature I see is “40 IDTP 1 3 C/3C1”.
It was delivered on a ’71 911T except USA engine
Types 911/03 and 911/06.
http://forums.pelicanparts.com/uploa...1084226136.jpg
If you need I can send a larger image or type out the specs.
Best,
Grady
3liter914-6 05-10-2004 01:59 PM
Re: What is Weber 40IDTP3?
I think they're pretty much identical, with the exception of the jetting. The IDTs were originally fitted to T engines and the 914/6.
jchatfield 05-10-2004 02:09 PM
Grady:
Could you send a larger pic, I cannot quite read the chart. I tried to blow it up, but it was then to fuzzy to read.
Thanks,
Jim
Grady Clay 05-10-2004 02:43 PM
Try this one.
http://forums.pelicanparts.com/uploa...1084228531.jpg
The two line captions that are obscured by a greasy fingerprint
are; "Idle air bleed" and "Pump inlet valve."
Best,
Grady
