Sonic dB's Avatar
Removing Carrera Front Valance
Can anyone post a diagram on this...where the connections are etc?
I couldnt find it in Bentley. Basically, I want to take it off and fix a couple of small dings. I could probably figure it out but a diagram would be useful. Thanks.
Old 05-16-2004, 09:16 AM
GB83SC's Avatar
Take of the front tires, loosen the side accordian's and open the hood there is two bolts in the very front of the car, just behind the license plate area.
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 05-16-2004, 09:22 AM
cary's Avatar
Open the trunk. Should be 2 right under the jack. One in each corner. You should see an M10 bolt head with an oversized flat washer.
Then on the flange from the bumper to the valance they'll be 2/3 nut/bolt combos. If you have a washer tank. That pair is a b***h.
Almost easier to take out the washer tank. But putting the tank back in is a b***h. Getting the bolt that the tanks hangs on is pretty tough ( 2 beer job ).
Not real tough. Don't forget to unplug the fog lamp before you start.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 05-16-2004, 09:34 AM
