Wong Chip Vs. Factory Chip via LM-1
Here are a couple of indicative runs using the factory chip...
and Steve's most recent iteration of his chip for the car...
The car is a 3.2 with a premuffler in place of the cat and a dansk sport muffler. Otherwise the car is stock.
The AFRs running with the factory chip are on the lean side. Steve's chip nicely pulls the AFRs down to a more appropriate level and has the AFRs bouncing just under 13. The red line is WOT switch with the no signal zone indicating WOT. 2-second smoothing has been applied on both graphs.
Steve reworked my chip at least five times last year. I was driving him insane with LM-1 logs showing inconsistent results. We finally figured out that the variances we were experiencing were due to my use of ethanol blended fuel from time-to-time. Seems that stoich, or the ideal AFR for ethanol is quite a bit different than gasoline, so even a 5% ethanol blend will significantly skew the AFR results as well as changing the target range for optimum AFR.
All in a day's work for Steve...
Old 05-26-2005, 07:23 PM
