-   -   911 C3 sway bar & t-bar setup (http://forums.pelicanparts.com/porsche-911-technical-forum/162491-911-c3-sway-bar-t-bar-setup.html)
JaniM 05-11-2004 04:01 AM
Fellow C3 owners question for you? I have been trying to find info about what is the standard C3 setup for sway bars & t-bars. I measured my sway bars and i have 22mm in front and 20mm in back, but according some books that should be the later turbo setup or am i totally wrong.
echrisconnor 05-11-2004 06:20 AM
I don't have my car with me to take measurements, however I was not under the impression that the C3 had any turbo suspension components.
Rick Cabell 05-11-2004 07:03 AM
(This is Noah writing) -- I've got the tech book at home, will check it tonight. If memory serves, the C3 had the same size sway bars as the early 930, 20/18 or 22/20. I'll post the correct specs later today.
