Auxilliary Air Regulator
Where does the metal (and rubber) u-shaped tube that comes off of the AAR end up? It vanishes behind the engine. I've found that wiggling the end that vanishes will drop a runaway idle. Anyone else have this experience?
'80 SC
Old 11-07-2004, 05:59 PM
it branches into a Y. one end comes up to the round silver/gold canister thingie (not sure what that thing is or does), the other end goes over to the airbox and hooks onto a little block right under the coldstart injector. I think the theory is the fast idle air pulling past the cold start injector helps atomize the fuel during cold starts.
Sounds like a loose clamp or cracked hose. Either one is totally aggravating to do anything about.
76 Targa patched 2.7
I have severe while-you-are-in-there-itis.
Old 11-07-2004, 06:58 PM
Designer King
Paulporsche's Avatar
See
www.pelicanparts.com/911/911_Parts/1978-83/1-7-2.JPG
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-07-2004, 07:07 PM
