What color is this?
I striped my 1973T down to the tub, I pulled out all the wiring, gas tank, suspension... I noticed that what i thought was conda green is not. It looks more like viper green. The car was painted by the previos owner. It was paintedconda green. I dont mind because I like Viper green better than conda green. The code on the door reads:
225-8-2 I also wouldnt mind seeing some of your viper green cars if you have pics. Thanks! Here is what she looked like before the teardown. http://forums.pelicanparts.com/uploa...1084302452.jpg |
Yes paint code 225 is Viper Green which was a 1972-73 color. Conda green is an earlier color of almost the same shade. Viper and Conda Green are some of my favorite early 911 colors.:)
Thanks Brian. I only noticed the difference in color when i took the interior out. Also in the front trunk. Viper green will make a great color for my RS clone.
I have a 74, which looks very similar in green to the above pic. Which green do I have?
Judging by your profile posting it says emerald green:) Check your drivers side door and get the #s on the black and silver plate below the the pin switch. Then post your findings and some fellow pelicanite will help you with you question. Thats what i did and got my answer.
Joe |
| All times are GMT -8. The time now is 01:27 PM. |
