Rear brake hoses different ? '67 912
So, i was putting all new brake lines in today on my '67 and made an unexpected discovery, now im not sure what to do. The two rubber brake lines from the rear were different from each other, one is a female on one end and a male on the other. The other hose is a female on both ends. This was becasue one of the rubber hoses went from a female T-fitting to a male steel line. The other hose went from a male steel line to another male steel line. The problem is that the new hoses that i got for the rear were both male to female, and i cannot find anywhere that i can order a rear brake hose that goes from female on one side to female on the other. However, the front brake hoses are female on both sides so i could theoretically use one of these (?) but they are a little longer. Has anyone ran into this problem? What would you reccomend?
Here is a picture of the two old rear hoses and one new front hose. The middle hose was cut just to make it easier to get off.
Old 05-26-2005, 04:31 PM
