-   -   Front Condensor Fan (http://forums.pelicanparts.com/porsche-911-technical-forum/162664-front-condensor-fan.html)
Phattey 05-12-2004 04:59 AM
Front Condensor Fan
Is the front condensor fan hard to replace? Mine is starting to whin a little and I'm sure soon it'll need replacement.
Thanks...Phattey
Rot 911 05-12-2004 05:00 AM
No it comes out quite easily. Unplug the electric connector. Unscrew the sheet metal screws and lift out.
david914 05-12-2004 08:21 AM
Before you order a new one, pull the existing one out and make sure it's clean. Road debris tends to find its way into the squirrel cage and cause the fan to get off balance (and therefore, noisy). Like Kurt said, it comes out easy.
Phattey 05-12-2004 09:22 AM
Thanks....is it accessable from the bottom of the car or from above??
Phattey...
rzepko6194 05-12-2004 10:24 AM
Phattey...
From above. You do need to move it back a bit as you're pulling it upward. I just removed mine last night for cleaning and a general inspection.
masraum 05-12-2004 11:46 AM
JP, quit posting and start driving! Only 17K miles?? You are WAY behind and desparately need to catch up!!!
rzepko6194 05-12-2004 11:55 AM
I know, I know.
My daily commute is only 2 miles, so I don't use the Carrera for work. I also have 3 other cars and two bikes, so I don't get to drive each one much.
As I plan on taking a long trip in the near future, I should crack that 18K barrier by July! ;-)
MBAtarga 05-12-2004 03:36 PM
You should unplug that motor now, before it seizes and causes an electrical fire. This is not an uncommon event.
rzepko6194 05-12-2004 05:20 PM
There is a factory inline fuse available kit available from Pelican which should help prevent an electrical fire in the event of a motor seizure.
konish 05-12-2004 06:26 PM
Oh, and if you have to replace the motor buy it under the Bosch part number and save $200..that is about $90 vs. $300 for the Porsche part number. Also, getting the squirrel cage off is a complete PITA. Before you even attempt it, remove the set screw and submerge the shaft in liquid wrench for a couple of days, heat the thing with a propane torch and submerge it again for a day or so. Even then, I ruined one cage in the process. Next time, I'll probably figure out a way to press the shaft out...the cage itself is pretty gracile and won't take much abuse. Finally, drill a small hole in the housing to access the shaft. That way a shot of WD-40 or liquid wrench can be applied on a regualr basis keeping the shaft rust free and helping it last a good, long time. Seal the hole with small rubber plug...
R/
Dustin
KNS 05-12-2004 07:58 PM
Does anyone now the name or part no. for that inline fuse kit?
rzepko6194 05-13-2004 07:26 AM
It's called a chassis harness, Pelican part OEM-91161207700, price $22.76.
KNS 05-13-2004 09:31 AM
JP,
Thanks for the number!
Kurt
Hugh R 05-25-2005 03:43 PM
What's the part number for the Bosch front condensor fan? I had a "Behr" part number on my burned up (literally) fan. Anyone know where the best place to get one is? Pep Boys or a German car dealer. I googled the part number on the side of the fan and didn't get anything. I was thinking of using a couple of stacked 4" 12 volt computer fans with some duct work, any thougths.
aigel 05-25-2005 03:55 PM
Note that a lot of folks throw their A/C out and can sell you a good fan with housing for little money. Just put a want ad in the classified section. I sold my fan there to someone that had a WTB post.
George
my85911 05-25-2005 04:45 PM
$22.76 for an inline fuse?
Not to knock the house, but $22.76 for an inline fuse holder and fuse!!!!!
"I sold my sole to the company store.......?
Hugh R 05-25-2005 05:53 PM
Aigel:
I'll try posting a WTB. Got one last year used and I put it on the bench and let it run for an hour and it literally caught on fire. A very good condition used is OK, but I'd consider a new one if the price is not userous.
kqw 05-25-2005 06:33 PM
Easy job...you may want to loosen the battery to make sure that you get the fan snug into the opening.
my85911 05-26-2005 01:50 AM
Do they glue or apply an adhesive or some type of gasket to the fan's plastic housing to seal it to the trunk floor. I remember mine being all cracked around edges, like someone tried to pry it out (maybe they forgot to take the screws out first).
kqw 05-26-2005 02:01 AM
No adhesive... but there is a small gasket sealing it to the trunk floor.
As mentioned about loosening the battery, it helps when trying to maneuver the intake of the housing into it the opening in the valence.
The reason for cracks is that some folks over tighten the assembly.
Hugh R 05-26-2005 03:30 PM
Anybody know where I can buy the front condensor fan for an 84 911? Part number, best price?
