-   -   Allignment Question (http://forums.pelicanparts.com/porsche-911-technical-forum/162780-allignment-question.html)
Alan Goettel 05-12-2004 07:45 PM
Allignment Question
Sorry if this has been asked a million times. I did turbo tie rods, bump steer kit, bilstein sports and Toyo RAIs, and i will be getting the car alligned on Friday. I will be using the car for street and track (RAIs only for track). What would be a good alignment comprimise?
Thanks,
Alan
Driver8 05-13-2004 06:32 AM
Alen,
What year and model car? I Have an 87 911 and here are my alignment specs.
Front Camber 1.5 deg
Back Camber 2.5 deg
Front Caster 6.5
Rear Caster 6.5
I would also recommend a corner balance as well. See you at the Glen next week.
Aaron
ChrisBennet 05-13-2004 06:59 AM
On my '86 I ran 0.9f/1.5r negative camber. .9 degrees was the most I could get in the front. I didn't notice any tire wear issues and it was mostly a street car.
-Chris
Alan Goettel 05-13-2004 07:59 AM
thanks dudes.
Green 86 911. Driver8 was an instructer of mine last spring at icy lime rock, i do believe.SmileWavy
Driver8 05-13-2004 09:16 AM
You are correct sir.
IROC 05-13-2004 09:43 AM
FWIW, there is no "rear caster". Anyway, I run about 1.5 degrees negative camber front and about 1.3 degrees rear and zero toe front and rear. Caster is whatever it is - as long as both sides are the same, it doesn't matter tremendously.
I haven't been on the track in awhile (and it's killing me) and my front A032s have suffered from the camber.
Mike
