vash's Avatar
quick question..TO bearing & pressure plate?
is putting the two together a DIY job? will i need a press of some sort. i dont get it.
cliff.
thanks.
poof! gone
Old 08-04-2006, 09:51 AM
19 years and 17k posts...
azasadny's Avatar
Cliff,
Here's some documentation I used when I replaced my clutch last month..Hope it helps!
How to remove throw-out bearing retaining ring?
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-04-2006, 10:13 AM
vash's Avatar
ART! i am gonna try it in my office! that was excellent. thanks for the play-by-play! '
cliff
poof! gone
Old 08-04-2006, 10:18 AM
vash's Avatar
ok, that wasnt hard. quick question. looking at the pics. #10 is installed with the concave (cup) facing up, and you didnt take a pic of #9?
i installed it:
bearing first, thin washer, concave finned thing/washer/spacer, pressure plate, notch washer, then lock ring...right?
btw, i got smooth rolling with Zero wobble. my old one jiggled and wobbled about .25 inch in every direction.
poof! gone
Old 08-04-2006, 10:37 AM
azasadny's Avatar
Cliff,
Take another look at the diagram, I believe you have 1 washer, then the concave washer, bearing and plate, then the big washer and then the small, locking ring. Check the diagram carefully as I may be remembering it wrong. I believe the concave washer was installed "cup up". You'll know when you have it "right" because ther will be no "wobble" at all, it will be nice and tight and the throwout bearing will spin freely.
Art Zasadny
www.ford.com
Old 08-04-2006, 11:08 AM
azasadny's Avatar
Cliff,
Just reread your note, I think you've got it! Excellent work!
Art Zasadny
www.ford.com
Old 08-04-2006, 11:09 AM
