Hello Ray !
Thank You ! |
MSD Installation....
I put an MSD in my '80 SC recently. I relocated the rear defrost relay to lay flat under the MSD. That left plenty of room for the M6A box. I also put crimp on 1/4" male connectors on the MSD wires and simply plugged them into the 6 wire master plug. Piece of cake!
http://forums.pelicanparts.com/uploa...1084591947.jpg Fred Cook '80 911SC coupe |
Thanks to everyone!!! I put the MSD in last night and she fired right up. The only drawback is that I now have to go back and get the Tachometer working. At least I am driving her again!!
http://forums.pelicanparts.com/uploa...1084900202.jpg
Here is what I did. I extended my electric plate out to hold the MSD as well. I kept as many componets in there stock positions as possible. For those who are not aware the ground is located between the MSD and Crane in the engine bay once mounted up, thats why it is open so I can access it. |
Msd
| All times are GMT -8. The time now is 12:42 PM. |
