-   -   First 100 Miles on a new 3.4 (http://forums.pelicanparts.com/porsche-911-technical-forum/163090-first-100-miles-new-3-4-a.html)
rdane 05-14-2004 08:13 PM
Finally had a chance to turn the key on my new engine this afternoon. (SC 3.0 is now a CIS 3.4)
Sounds like a sewing machine. Although it is a bit loud...louder than before. Hard to figure out exactly what is different when you are stresed about the first 100 miles and breakin.
But here are my thoughts for the moment. LOTS more torque. It used to kick in around 4K on the dyno. You can now see the cam come on and the tach jump and the car start pulling hard at between 3100 / 32OO until you let up. So much torgue I would have sworn I was in 3rd once but was actually 5th. Pulls like the proverbial freight train...even this new and @ 100 miles.
Engine came in $1400 under budget, surprizingly and came out a pretty color too :) More later.
dd74 05-14-2004 08:38 PM
Photos...:confused:
Schrup 05-14-2004 08:44 PM
I get all moist just thinking about it Dane, can't wait to hear it this weekend!!! BTW after JW properly adjusted my valves my motor sounds like a Singer too, he said they were way out.
Mark Wilson 05-14-2004 08:46 PM
That motor sounds more like a freakin turbine than a singer. Looks awesome too. Great job Dane!!
http://forums.pelicanparts.com/uploa...1084596281.jpg
http://forums.pelicanparts.com/uploa...1084596314.jpg
rdane 05-14-2004 08:52 PM
Thanks guys. Paul the house, son and car looked great. Looking forward to seeing your "new" ride.
As you can see we back dated the heater and added a little paint in there. Best part is actually being able to see the left bank of plugs and the powder coated sump cover ;)
Scooter 05-14-2004 09:01 PM
Re: First 100 Miles on a new 3.4
Yeah, going up the mountain on I90 doing 100 mph, pulling like your in 3rd...I would say there is some torque there. Seemed kinda sad getting back into my car Dane. Very impressive!
3liter914-6 05-14-2004 09:13 PM
Congratulations. Nothing better than not just getting a project done, but bringing it in under budget.
http://www.pelicanparts.com/support/smileys/wat6.gif
dd74 05-14-2004 09:20 PM
I like it! Very nice. Hmmm...I bet my little ring and pinion wouldn't last past the break in period with all that torque. What do you guys think? Would a 7.31 r/p last with a 3.4 like Dane's?
surflvr911sc 05-14-2004 09:35 PM
From all the discussion I've seen here there should be no reason a 7:31 915 wouldn't last, if it had all the proper upgrades.
Great job, the engine looks awesome, I can only imagine how it feels. I do know torque though and you’ve got to love it!
RANDY P 05-14-2004 10:03 PM
Whooo Hoo!
Very nice!
rjp
}{arlequin 05-14-2004 10:15 PM
Congrats. I was cheering for you.
Jack Olsen 05-14-2004 10:19 PM
That looks great -- and I bet it pulls even better. Congrats!
Mikkel 05-15-2004 01:06 AM
Congrats. Are you going to have it rolling road measured after the break in period? It could be interesting to know how much torque has improved.
rdane 05-15-2004 01:43 AM
Thanks so much guys! The members here made this one possible. Funny enough it isn't a 3.6 but then again it isn't a 3.0 either :) Going to take some getting use to as it is pretty easy to spin the tires now on dry pavement in first gear.
After 5 months of being without my wheels...just wanted you guys to see what I would be doing in the morning as the sun comes up!
http://standingwave.org/albums/porsche/adw.sized.jpg
Back to the original Fuchs now. Once I hit 1500 miles I'll switch to Mobil 1 and then dyno the car on the same machine I used last year. That should be an interesting comparison as I was 182 rwhp and 162 on Torgue or 215hp at the crank with my 3.0. Plan is to dyno the 3.4 as a single plug and then twin plug late summer and see what the difference is.
Bob's Flat-Six 05-15-2004 04:00 AM
The color looks like Moca?
I like the look and I'll bet that motor is sweet, wish it was in my ride :)
Have fun , Dane
Elombard 05-15-2004 04:10 AM
I have been waing for this!!
What did you decide on the wheels? Sold the FIKSES and ??
Shuie 05-15-2004 05:26 AM
I cant believe I missed this.
Congrats Dane! Im glad to see that car back on the road.
ttweed 05-15-2004 06:35 AM
What did your compression ratio end up at? Are you running race gas now with the single plug setup? What ignition are you going with when you twin plug?
Looks very nice. Good job! I bet you're smiling now.
TT
Superman 05-15-2004 06:54 AM
Awesome, Dane. Can't wait to see it Sunday. I love the engien appearance. I like sleepers, but I also like colorful engines.
I would guess that the 20/21 cams make good use of intake air velocity. the reason I say this is because my engine (still a 3-liter) certainly responded well to the cams with its narrower intake runners (causing air to achieve higher velocity), and now you're getting the same FAT SMOOTH power band with the wider runners, perhaps due to the increased volume, and consequent increased velocity. It's a theory we can discuss Sunday.
There will be at least a couple of winter projects unveiled then. Pretty exciting. Congrats, Dane. Enjoy.
rdane 05-15-2004 07:07 AM
Custom offset, 16" two piece Fuchs, anodized, 8" and 9.5" with 225x45x16 and 245x45x16 SO3s.
Another topic altogether ;) Compression ended up 9.83:1 with a 1mm shim at the cylinder base. So no need for race gas, thank goodness. Motor nearly made Washington smog with zero miles. So while I don't have that issue any longer because of the date of the car I spec'ed the engine so it would smog if ever required.
I will be be doing the Electromotive HPX twin plug set up. Really curious to see what the dyno says with and without race gas in both versions and the result of the twin plugs.
Jim, I took some care to get as much as possible from the CIS. New injectors, lwt Pauter rods, bumping the compression as high as I dared for a street car, the improved CIS/motronic pistons, bored throttle body, and the case/cylinder work. We'll need another group dyno day soon!
You and Paul did an awesome job on his car. Really looking forward to seeing it in the morning.
Elombard 05-15-2004 07:16 AM
Awesome
Did you post the details on the wheels? Cost, manufacture etc. Sounds unique.
rdane 05-15-2004 07:33 AM
"Did you post the details on the wheels? Cost, manufacture etc."
Funny you should ask EW ;) Mark Wilson (of red duck fame) and I have gone into the wheel business.
I'll need to clear it with Wayne before we go into more detail.
fintstone 05-15-2004 07:38 AM
Very nice!!!!Of course I liked it before. Congrats on a great project/car. I look forward to hearing more about it as well as your new wheels.
Kevin Stewart 05-15-2004 09:02 AM
rdane, glad to see you got it running, Hope everything works out for you, Kevin
Craig 930 RS 05-15-2004 12:19 PM
There is something pretty cool about thinkin' outta the box - and you sure did it with this motor. A CIS 3.4.....way to go!
Let's give a guess as to hp on the Dnojet 248C that my car and Dane's car has and will run on - the exact same machine.
My guess? 220 at the wheels.
Craig
@RS
Craig
@RS
rdane 05-15-2004 12:47 PM
Hey Craig, remember I was 183hp at the wheels before with the original, 25 year old 3.0 and a 8.3:1 compression ratio :)
I am looking for 225 single plugged. But the shadow of this is looming over me until I have the miles and dyno time.
http://forums.pelicanparts.com/showthread.php?s=&threadid=158331&perpage=10&pagen umber=3
When is your 3.6 monster going to be finished? You coming to the swap meet for breakfast in the morning.
kiesan 05-15-2004 02:46 PM
I was at Gerber/Goodman doing a bike deal for one of the employees and I saw a technician degreeing your cams. A few days later, I was back actually dropping off the bike and your car was being washed and driving around. Sounds impressive. I can remember degreeing my cams around 11/2002 and driving my car for the first time later in the month of November only problem it was 2003 instead of 2002.
Glad to hear you'll be making use if the extra 6 spark plugs sometime soon.
dickster 05-26-2004 11:04 PM
rdane
sounds great. is that a two out dansk in the photo? what size tips? looks nicer than my dansk setup.
http://forums.pelicanparts.com/uploa...1085641429.jpg
rdane 05-27-2004 08:23 PM
Rich, it is a 2/2 Dansk. I suspect they look the same just different bumpers.
Snow in England? Tell me it aint so?
JRISER 05-27-2004 08:31 PM
Sweeeeeeeeet!!!!!! I really like the engine detail, too! Looks like you did a really nice job. Very clean.
rdane 05-27-2004 08:43 PM
Thanks John...you are soooo lucky I don't repeat post the rest of the pictures ;) I am worse than a proud pappa with this car.
JRISER 05-27-2004 10:33 PM
You have something to be proud of.;)
dickster 05-28-2004 12:22 AM
rdane
sorry, i got tied up last night ;)
no, yours definitely look smaller to me - if you get a chance could you measure the diameters for me? appreciated.
no snow at the mo (!) - that was taken some time ago.
rdane 05-30-2004 04:14 PM
Dickster, the outside dia. is 69.34mm or for here in the USA 2.73"
dickster 05-31-2004 05:10 AM
thanks for that - i thought as much, mine measure 82mm outside diam. that 13mm makes a lot of diff.
cheers.
