-   -   Project 73 911 R/RS -- Week 7, part 1 (http://forums.pelicanparts.com/porsche-911-technical-forum/163312-project-73-911-r-rs-week-7-part-1-a.html)
Shaun @ Tru6 05-16-2004 08:11 PM
OK, so it's really like weeks 7 and 8, maybe 9 too, but at progress is being made. Cage is coming along, car has full brakes and body panels are starting to go back on. The pics...
Complementing the 84 suspension are a set of early Turbo calipers. The rears need to be machined, and both F and R need shims/spacers to fit the stock mounting points. Rear discs are OEM Turbo, fronts are custom Colman's to fit custom hats. Everything bolted together quite nicely, the toughest part is keeping shims on the bolts while getting the calipers on.
A 23.8 mm Mercedes unboosted master cylinder and new lines will complete the circuit.
http://forums.pelicanparts.com/uploa...1084761835.jpg
http://forums.pelicanparts.com/uploa...1084762026.jpg
http://forums.pelicanparts.com/uploa...1084762098.jpg
Test spin:
http://forums.pelicanparts.com/uploa...1084762146.jpg
The rears require a bit more work. Rear calipers need signigicant machining. Stock 84 trailing arms. Note the little tabs top and bottom just fore of the hub. these need to be cut off and the mounting hole corners rounded over.
http://forums.pelicanparts.com/uploa...1084762258.jpg
http://forums.pelicanparts.com/uploa...1084762297.jpg
I used a cut-off wheel on the grinder to get these off, followed by a Dremel cut-off followed by a flap-disk sanding wheel to clean up the area.
http://forums.pelicanparts.com/uploa...1084762398.jpg
The finished product
http://forums.pelicanparts.com/uploa...1084762423.jpg
A few pics of the cage in process. James (JPAchard) is handling this area. The end product will be a full RSR style cage with F and R suspension tie-ins and beefy side intrusion given the tin foil doors I picked up from another member.
Some detail:
http://forums.pelicanparts.com/uploa...1084762589.jpg
Macro view:
http://forums.pelicanparts.com/uploa...1084762640.jpg
Jump to Part 2:
http://forums.pelicanparts.com/porsche-911-technical-forum/163313-project-73-911-r-rs-week-7-part-2-a.html
CHILI 05-16-2004 09:17 PM
Very nice!
I'm curious about one thing, though. How come no cross bar on the cage?
Kraftwerk 05-16-2004 10:18 PM
Nice Work Shaun!
Shaun @ Tru6 05-17-2004 04:20 AM
Originally posted by CHILI
Very nice!
Thanks Chad, the cage is still very much a work in progress. door beams and cross bar will be done this week. Once the cage is done and painted, the interior mechanicals can all go back in.
ttweed 05-17-2004 09:33 AM
Shaun-
Thank you for documenting your project and posting the pics. I am sure there are many people here that have found it very interesting and informative. Keep it up.
TT
ps- looks like you will have one sweet ride when you get done!
onewhippedpuppy 05-17-2004 10:28 AM
Damn, you don't screw around. Looks like things are going good, very nice.
irl 05-17-2004 11:10 AM
Painting
Nice work, I am going through a rebuild myself and your images brought up a question I was going to ask the board. How far will you going putting it together before you paint. You have a lot of the suspension going on, is it Ok to not worry anout overspray.
Shaun @ Tru6 05-18-2004 04:51 AM
Re: Painting
Good question. One school of thought is to get the bare tub rust-proofed with POR15 or Wurth, get the cage in, get the body panels trial-fitted and then shoot the entire car.
I am going another direction. I like the silver Wurth Rust Guard becuase it is bright and tough, and therefore easier to see in and around work areas like engine bay, suspension, front trunk. I would not want to work in a dark blue (body color) engine bay.
But even better for me is that by having all mechanical areas Wurth Silver, I can assemble the entire car, even get it drivable, and then spray the body. My plan is to paint the entire plastic front end off the car, paper over the entire front end, all door and window openings, engine bay and rear inner wheel wells.
With a good day of taping there should be no overspray, a perfectly blue body and bright silver mechanical areas.
Cornpanzer 05-18-2004 05:37 AM
Car looks great Shaun. WHen do you expect to be driving again?
Shaun @ Tru6 05-18-2004 08:24 PM
Driving versus drivable versus legal. hmmmm.
I think mid-June is pretty realistic at this point, depending entire on paint.
Oh, and I also just quit my job to start a new business or 2, so budget is extremely important.
We'll see what happens this weekend.
S
}{arlequin 05-18-2004 09:26 PM
very nice Shaun. Good idea on the bright color for the dark areas. Many racer build ups use that concept and I considered doing that if I ever did an extensive rebuild like yours, but I was always curious if anyone would actually go that route for THEIR 911. Good job.
BigD9146gt 05-26-2004 04:51 PM
Gorgeous...
