911 sc ride height
I need to raise the ride height on the back of my 78 911sc. To adjust the spring plate cam bolt does it require a special flat wrench to hold the bolt on the inside or is the plate threaded?
Old 05-18-2004, 07:47 AM
Binge User
Schrup's Avatar
You need a 36mm X 24mm thin wrench like the one in the pic. I picked on up at a bicycle shop for $12. The host sells them.
Paul
Old 05-18-2004, 07:52 AM
