Mike the mechanic's Avatar
930 won't start
This 1988 911 turbo had a shorted out alternator, which I replaced. Now, the car cranks but won't start. I checked for 12v at the coil with the key on, no power. I checked for 12v at the ignition control, no power. When cranking, the fuel pumps don't even go on.
Does anyone know if there is a fusible link or other fuses somewhere in the car for these things? All the fuses at the fuse box are ok, and the ignition switch is working fine. Any help would be greatly appreciated, as I have no wiring diagram for this car.
Thanks!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 05-22-2004, 04:45 PM
bump
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 05-23-2004, 05:44 AM
Raynald's Avatar
Hello Mike !
did you check all your ground ?
Raynald
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 05-23-2004, 09:25 AM
Mike check your ground I had the same problem
Old 05-23-2004, 10:28 AM
Hey guys, thanks for the replies. Which grounds exactly are you talking about?
thanks!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 05-23-2004, 09:25 PM
Mike Ther is a group of groumg wire that come from the fuse panal in rear od the car and the connect to top pf the chain tetioner cover
Old 05-24-2004, 08:11 AM
