-   -   Brake Caliper Piston Alignment (http://forums.pelicanparts.com/porsche-911-technical-forum/163743-brake-caliper-piston-alignment.html)
PorschePilot 05-19-2004 11:56 AM
I am rebuilding the brake calipers on my 74 911 and I want to know how close do I have to be to the 20 degree piston alignment. Can I eyeball it or do I have to get it exact? What happens if it's off by a little?
Bill Verburg 05-19-2004 11:58 AM
As w/ most things in life the closer to spec the better. It's easy enough to make a tool that will allow fairly exact orientation.
Neilk 05-19-2004 01:04 PM
Print the picture out, cut out the angle and trace it onto a a piece of cardboard. Voila!! You have a tool.
Angle courtesy of MS Paint.
http://forums.pelicanparts.com/uploa...1084997010.jpg
PorschePilot 05-19-2004 01:54 PM
Thanks!
