SRISER's Avatar
Quarter window removal?
How do you remove a quarter window from the body without removing the window from it's seal? I have to install a new trim piece between the bottom of the quarter window seal and the body. Thanks guys.
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 05-25-2004, 07:10 AM
SRISER's Avatar
Nobody?
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 05-25-2004, 09:56 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
what year?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 05-25-2004, 10:32 AM
The window should push out from the inside , assuming its non hinged .
Jim
Old 05-25-2004, 10:33 AM
Assuming it is on your 88 coupe, you need to, from the inside, pry the rubber over the ridge on the body that retains it. Basically, using some appropriate tool, start prying the rubber up from the inside. Push the window outward while you are doing this. The rubber seal will eventually push over the ridge/lip that is on the body.
Then you just push the whole assembly out.
Don't mess with the metal trim piece that is on the window/rubber/trim assembly, i.e., don't pop the metal trim out if you can help it. To reassemble, use the "rope trick."
Old 05-25-2004, 10:48 AM
SRISER's Avatar
Thanks. I knew that you guys would come through. Now, the other quarter window is sqeaking when I turn right...very weird.
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 05-25-2004, 10:58 AM
