drag racing the short bus
Tom: does this help?
The Terror of Tiny Town |
GREAT job!
Dave what year is your SC? Jim/superman has a back dated OEM exhaust, not SSIs. This is a stock '81 with SSIs again done on the same day and dyno. http://standingwave.org/albums/porsche/als.jpg Last edited by rdane; 05-21-2004 at 11:14 AM.. |
Hilbilly Deluxe
If you have a better version, or a hard copy, maybe you could just pull the numbers out for me. Dane, cool, I can work with that one. Tom |
Dane: mine's an '83 SC engine - bone stock w/backdated exhaust and a Triad dual-in-dual-out muffler.
Tom: that's the best I can do for now. The hardcopy's at home...somewhere... Jack Olsen completed the original scan, so he might have a hardcopy. Jack? You around?
Hilbilly Deluxe
Updated.
![]() What I would really like to have is a graph for an otherwise stock early SC with backdated exhaust. Tom edit: fix chart Last edited by emcon5; 05-21-2004 at 01:28 PM.. |
Hey guys, this is great stuff!!
Not to throw a monkey in here, but it would also be interesting to note other engine variables (i.e.: CR, ignition timing, cam timing lift, intake/exhaust port sizes, exhaust setup, etc) just so we can be better educated and start piecing together WHY a particular engine setup performs a certain way. BTW: I still think Noah's Carrera 3.0 is a freak of nature . The reason Noah gets 200+ HP at the rears is because he's able to sustain a higher torque# in the high RPM's....that engine breaths very well. It would be nice to know where Noah timed his cams, his current exhaust setup, intake/exhaust port sizes, etc. We could use this other info. to start dissecting the finer points and (for example) see/understand why Noah's engine is able to sustain a high RPM torque#.I'll Start: CR: 9.7:1 Cam Timing: 2.0mm (range 1.8-2.0mm) Ignition Timing @ Time of Dyno: 38 degrees @ full advance Intake Ports and Runners: 36mm Exhaust Ports: 35mm (stock) Exhaust: SSI's/Dansk Sport Misc: Sachs lightweight pressure plate/clutch
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
Tom any chance you could add some of the new dyno sheets being posted to your graph?
Is there any concrete evidence as far as advancing or retarding cam timing for better performance? I read in BA's book that Porsche experimented with this, but in the end, it didn't make an enormous difference.
If one were running low CR but wanted to run the 964 cam would changing cam timing make this cam any more or less compatible?
'76 911 Carrera 3.0 |
What a great thread! REAL DATA, not just hearsay. Way to go guys. I need to track down my dyno sheet so I can add to the 964 cam results. Cheers,
Bob Piper 78 911SC "Bullseye" SOLD 00 540i 02 CBR 954RR 98, 00, 03 sons |
Now in 993 land ...
George |
Now in 993 land ...
![]() I also think the thread is mainly about driveability in town etc. If you are talking performance at a track, you don't care what's under 3500 or even 4000 rpm. So if you can buy some power in the high end and pay for it a bit at the bottom, it is good. Just a few random thoughts! George |
The M1 cam we came up with would be worth trying for a comparison. WK
I have had the best results with the M1 cam made by webcam. I sell them if anyone would like to try them. Much better than 964 or 20/21 KNIGHTRACE@MAC.COM Thanks, William
I am not sure how to post this info , so here is the link to another Pelican thread
3.0 rebuild for performance advice Good dyno curve and more info on page one Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
