Poll: Pick A Cam Profile
Poll Options
Pick A Cam Profile
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Best Cam Profile For A Stock SC?
Greetings All,
I’m nearing the end of my engine rebuild and have a dilemma. I want to step up my stock cams but I’m not to sure which Elgin profile to choose from? They have two profiles to chose from for my engine (SportSC/330 or 964) but I wanted to hear from those of you who are running either cam with similar specs to my motor. My motor is a '78SC 8.5 compression ratio and the larger early SC intakes, boat tailed case, and a stock exhaust but is slated for headers and a dual in single out.
I did a search on the cams and have found good replies on both profiles. So which one would you recommend for a mostly street/canyon car with a few DE's a year.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 05-20-2004, 02:03 AM
Now in 993 land ...
aigel's Avatar
If you searched the archives, I am sure you found John (camgrinder) clarifying Elgin's grinds. He clearly states that he wants to see higher than 8.5 compression for the 964 cams and that the 330 cam is what he recommends for the lower compression SC:
Elgin "super" SC Cam Grind
Cheers, George
81 SC (sold)
Old 05-20-2004, 02:15 AM
oneblueyedog's Avatar
Since I have the stock Mahle P/C's (new) I used the SC/330 cam grind. I timed the cams in the middle of the specified range. Deck height was measured at 1.3-1.4 mm Power surges on at around 3500r.p.m. and pulls without flattening to 6000r.p.m. My engine prior to the rebuild was out of breath at around 5500. I'm also running a colder plug from stock.
I boat tailed the webs too.
I think Dave at Elgin and Dema both said that this cam gave about 10 more horse power to the wheels. It was nicknamed "The Cheater Cam".
I have yet to dyno the car. I don't know what I had before the rebuild. The next two mods I make will be a Euro pre muffler and modify one of my 2 mufflers to dual outlet. Then I'll dyno it.
I have lost 2 mpg in fuel efficiency.
I did not realize the acceleration difference until a friend of mine drove it and I sat in the passenger seat. I definately had to strain my neck and back when the cam came on. He felt it too.
In hindsight I have no regrets at all. It's much more fun and different to drive.
Lee 78 SC
78SC coupe, Silver Metallic
Old 05-20-2004, 06:50 AM
Senior Member
Superman's Avatar
I have a strong suggestion for you. Maybe a couple. First, I can tell you that those of us who are using the WebCam 20/21 grind are VERY happy. My car pulls strong and smooth at 1000 rpm, stronger at 3000 rpm. Peak torque levels out at 4000 rpm and stays there until after 5000 rpm where it falls off very slowly. horsepower curve flattens at 5000 rpm and stays that way until past 6. This car has a power curve like a V8 and is highly fun to drive, as a result.
But there is evidence that you need air volume and air velocity, to make them work best. With your fatter intake runners and low compression pistons, you will not get this velocity. Since your intake system is much more robust than mine, you have the convenient opportunity to just change pistons, or P&Cs to solve that problem. You can use somebody's used set of P&Cs (mine are Alusil and I re-ringed them with no problem whatsoever) which should be available very cheap. Go with a set of the later 9.3:1 pistons, or splurge and get some JE pistons with the more sensible dome shape in the high nines (9.8:1 or something). This, combined with a good set of cams (like the 20/21), will make your car a fire-breathing dragon. You'll have a faster SC than almost anyone else, with minimum cash outlay.
Mocha 1978 911SC. "Coco"
Old 05-20-2004, 07:40 AM
Metal Guru
911nut's Avatar
All,
What would be the total cash outlay to re-grind the cams, including all the stuff that has to be bought in addition to the cam regrind (20/21 is $750?)
Also, can cams be removed/re-installed via a partial engine drop?
Thanks.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 05-20-2004, 08:33 AM
Now in 993 land ...
aigel's Avatar
For cams the engine has to be completely removed.
All you need is to regrind your cams and refurbish your rocker arms or buy new ones. Total bill for that is $750 if you include seals and buy new arms.
WebCams is real pricey since they reweld and reharden cams or even sell you new billet ones. I think that's overkill. You can have your cams reground to ANY spec at Elgin for much less.
George
81 SC (sold)
Old 05-20-2004, 08:37 AM
rdane's Avatar
From what I have seen on the dynos the 20/21 cam is a better tool for the 8.5:1 SC over the 964 cam. My USA '79SC was 185rwhp/215 at the crank with SSIs a sport muffler and 20/21s and 190K miles on the clock.
I used the same cam for a 3.4 CIS conversion and am very impressed this far (300 miles). Not always, but some times you actaully get what you pay for.
Seeing Superman's, mine and several 964 dynos I think the 20/21 is a better cam. I have not seen any of the Elgin dynos.
Old 05-20-2004, 09:37 AM
Now in 993 land ...
aigel's Avatar
I am not going to argue grinds. I think at some point it is a wash. People swear by this and by that. There is only so much that mild cams like these can differ. There isn't the magic grind that will produce 10% more than the other.
The original question in the thread was if a 330 or a 964 cam should be used. You have not added much to that discussion by pushing the web cam at twice the moolah.
What I wanted to add is that there is nothing magic about that 20/21 grind. Any other good cam grinder can set you up with exactly that pattern. There is no patent or IP on it that will keep someone else from grinding it for you. So, why pay twice the money at web cam? I guess someone has to help them pay for their ads in magazines ? I sure would rather contact John (camgrinder) and ask him what he cand do for you. Ask someone that has done this for decades!
Sometimes I am sick and tired of the fact that we Porsche people get taken to the cleaners for services that would cost a third if it were performed for an American racecar. The cams are a good example. There is no reason that they should cost as much as web cams is charging. Especially for the DIYer, the parts cost is a big factor.
Cheers, George
81 SC (sold)
Old 05-20-2004, 10:24 AM
smestas's Avatar
Thanks for the feed back guys!
I was told by the seller that the 330 cam was the way to go but I just wanted to hear what the entire collective here thought since I have the choice right now between the two profiles. I guess if I had better compression then the 8.5 the choice for me to go 964 profile would be easier. I’ve already ordered the 330’s but the little voice in my head last night kept saying “are you sure you don’t want 964’s and a few more ponies”.
I was hoping to see if there were any members out there with 8.5 compression with 964 cam profiles to see how they like them.
Simon Mestas
'78SC Coupe
Old 05-20-2004, 11:13 AM
rdane's Avatar
Lots of thoughts on cams. My feed back isn't from cost comparisons or personal preferenece just what I have seen on dyno results.
Cam grinds are typically proprietary and developed on dyno results. (or should be any way) May be it is all a wash but that isn't what I have seen from actual dyno results. When it comes to CIS and cams I would say it isn't the case at all.
It is a false economy IMO to not spend a few extra bucks for the right stuff the first time when the engine is apart. Labor is the issue the majoriy of time not the cost of the parts. The DIY's time is worth every penny of the professional wrenches. I would hate to regret using the wrong cam.
George says I haven't added much to the conversation. I spent almost a year collecting info on CIS mods and hot rods and the dyno results that back up the results instead of the typical horsefeathers that get spewed on a BBS.
There is a differenece in cams for a CIS system. Take a look at the differences in torque curves and where the engines run out of HP
if you want to make a comparison.
I have enough info to recommend the 20/21 over the 964 for this aplication because it is the same as my engine originally. But like I said in the first post, I have not seen a Elgin dyno to make a comparison.
Easy enough to get some good info by what Elgin posted on the other thread in their 330 and 964 comparison. Take the comparison I have already made between 20/21s and 964s, apply Elgin's own comments, and the performance preference for me seems obvious.
Web cam is an improvement on the 964 for CIS by the dynos. Elgin says his 330 is a better offering for the low compression cars over the 964. I would like to see the dynos.
VMMV but at least Superman and I added another data point that may have been missed because of budget restraints.
Old 05-20-2004, 11:21 AM
