Battery recommendations....
My battery is more than 4 years old and i need to get a new one.
what would you suggest? Are Optimas any good? thanks. |
Odyssey all the way. I have one and love it. Only set me back $70 for the non metal jacket version.
Superlight at 14.7lbs Rennline Battery Box Installation (pics)
'70 911T Signal Orange |
D idn't E arn I t
Optima Yellow
3 years, no issues. Perfect for street car.
(Pardon my dust, been awhile since I've been under there. time for some spring cleaning!)
In the movies only bad guys sleep in king size beds. |
Randy:
Why yellow...this isn't a trolling motor, is it, or you don'y have a megawatt sound system?... why deep charge and get a lesser warranty than a normal Red Top ( not deep charge)? Also...better get a cover for the "hot" post on tha battery !!! ---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
http://www.sears.com/sr/javasr/prod...pid=02827936000
how about this one? will it fit? and it only weighs about 31 lbs |
Friend of Warren
Just get the Optima Red Top unless you are into serious weight reduction.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Guest
Posts: n/a
I've been considering switching to an Optima for some time now. What's the difference between the red top and the yellow top? I have an '85 carrera with a 4 by 40 watt amp. Which would I use?
Search this BBS under likely key word phrases like battery.
Stock Carrera battery is a huge group size 49/93. Can go slightly smaller with group size 48/91. We have three different floor mounting holes to use. If a normal style battery, get one with a common vent port, and tube the gasses/liquid to the outside...more in the archives. --Wil
Jerry M '78 SC |
Guest
Posts: n/a
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=AUTO&pid=02827925000&tab=specs#tablink |
19 years and 17k posts...
Optima Red-top. I've had mine for 18 months with no problems! No leaking, either!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Was thinking of going the optima route but with the modification/fabrication required install the battery and with some battery not charging correctly, I decided to keep with the wet cell battery. Just install a acid mat under the battery if you are concern about acid corrosion. DieHard International Engineered to meet the unique characteristics of many European imports. Sears item #02833348000 Mfr. model #33348 |
D idn't E arn I t
it came with the car Car has an amplifier, and I swapped out the alternator out when I purchased it 2 years ago, haven't had a single issue with draw or further alternator problems. Been 30K since then. Normally, it's covered with carpet, so I don't fiddle with those funky covers. It's been literally a year since I've rolled back the carpet. rjp
D idn't E arn I t
PS-
Will, What is a "trolling motor"?
Put in a red top Optima in Nov 97, everyday driver, 100K miles later, good as new.
Robert Williams 70' 911T |
trolling means moving the boat slow while fishing
of moving thru something while trying to catch something viz. Watch the older law students trolling thru the new 1L girls.... |
D idn't E arn I t
Fishing boat -
long parking times. Duh. forgot that's the original use of deep cycle. rjp
Metal Guru
I put an Optima in my SC two years ago and almost got a double hernia when I went to lift it. That sucker is HEAVY. So when the battery died in my Taurus I stuck the Optima in it and bought a Westco for the SC, thereby saving 40 lb. (approximately).
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
