"klote" tach
Starting the engine and the tach works fine but a few miles later the tach seemed almost dead. It points 1000RPM less as before.
Engine runs great all the time.
When I put on the headlamps the RPM's drop also.
What can be the problem?
Maybe the earth connection?, I don't know.
Taco
Old 05-21-2004, 10:26 AM
Randy Webb's Avatar
CDI box going out? Before mine died it caused "drop-outs" in the tach.
Old 05-21-2004, 11:02 AM
It would help to know which year and model you have, but generally speaking, a lot of vague electrical problems are due to poor grounds (earths) and/or a failing alternator/voltage regulator.
Jerry M
'78 SC
Old 05-21-2004, 11:53 AM
just pulled out the tach and the ground wire was connected with another wire. These wire was connected to a little switche near the switche for the electrical roof?
I pulled this wire of the tach en went for a spin.
I seemed the tach was okee now, but by putting on the headlamps (is going dark in holland) the same problem occure (RPM on tach drops with 1000RPM's).
Saturday I check the ground wire.
Porsche 911S '77
Taco
Old 05-21-2004, 12:19 PM
