Handy New BBS Upgrade - Help me test in this thread...
After hearing about people complain about not being able to resize and fit images so that they could be uploaded, I decided to incorporate a resizing routine into the website. Please help me test it.
The image upload feature should now allow you to post any JPG or GIF image of any size. It will reduce the size of the image on the server, and also constrain it to be 800 pixels wide or less (no biggie pics that crowd the screen). Try it out please - post your biggie images here. -Wayne |
Tried it a couple of times, kept coming back "could not find server"
Explain... -Wayne |
Very nice feature Wayne!
That image was originaly 1600 x 1200 and about 864k. Now its exactly 800 x 600 and about 76k. Worked like a charm! |
:( Did not work:(
Ok here goes, Image original size is around 1.3MB and size is around 1536x2048 Cheers Jakes Did not work, this is the error I got You attempted to upload a file totaling 1383957 bytes. This exceeds the maximum limit of 100000 bytes (100k). Please go back and select a smaller image. [edit] I did mine using the attach multiple option, if that is of any help. |
Attempt to post image
Here goes Wayne:
Sorry, it didn't work. Here is the message: You attempted to upload a file totaling 439460 bytes. This exceeds the maximum limit of 100000 bytes (100k). Please go back and select a smaller image. Alan |
same pic saved as a huge 24-bit bitmap 2.25 mb. Using Xp pro and Explorer 6 128bits.
oops We're sorry, but you may only upload image files (with an extension of .gif or .jpg). Please go back and select a different file forget this one Wayne sorry :( |
OK, I'll throw in a Rennsport pic that started off around 225k:
http://forums.pelicanparts.com/uploa...1085139010.jpg Mike |
I posted a 550K photo in a new thread called test photo (by accident) and then another in the same thread - worked a treat - love it.
First try (btw, what an improvement in convenience that will be!!!)
Ooops...nuthin showin...got "too large size msg"... |
worked cool
http://forums.pelicanparts.com/uploa...1085139521.jpg :D |
Second try...same (large size picture)
No dice... You attempted to upload a file totaling 1301288 bytes. This exceeds the maximum limit of 100000 bytes (100k). Please go back and select a smaller image |
I am using the attach multiple - try that Paul
Trying another picture...
Nope: You attempted to upload a file totaling 1117059 bytes. This exceeds the maximum limit of 100000 bytes (100k). Please go back and select a smaller image. Oviously, my pictures .jpg are too big anyway.... |
here is my tryhttp://forums.pelicanparts.com/uploa...1085140641.jpg
I still get a message that it has to be smaller than 100,000.
| All times are GMT -8. The time now is 09:00 PM. |
