-   -   Flywheel Bolts, Replace or Not (http://forums.pelicanparts.com/porsche-911-technical-forum/164089-flywheel-bolts-replace-not.html)
Poorsche Man 05-21-2004 10:20 AM
Well I put the old flywheel bolts back on the flywheel although the engine is still out of the car. I understand that these bolts are expansion bolts. I torqued them down to the proper 115ft-lbs. Do these bolts really need to be replaced?
zac
MT912RS 05-21-2004 10:27 AM
Yep, those are stress to yield: i.e. good for one torquing.
Superman 05-21-2004 10:29 AM
Pressure plate bolts are commonly reused, although most folks are scared to reuse them. While PP bolts can (according to some folks) be reused, not so with flywheel bolts. Always use brand new ones.
Randy Webb 05-21-2004 10:49 AM
For the price, its good to use new PP bolts.
Also, you can put a _small_ dab of red Loctite on the flywheel bolts.
Be sure to torque properly and be sure the torque wrench is accurate.
for both sets, tighten a little bit at a time.
yelcab1 05-21-2004 11:05 AM
I am guilty of reusing my flywheels bolts many times, with red loctite, for many years with no issues.
I do not race, but drive very hard.
Your car, your money, your call !
Poorsche Man 05-21-2004 11:08 AM
Okay, good one other person. I didn't want to have to get back into the clutch as my engine is almost back together.
Thanks for the help
kqw 05-21-2004 11:19 AM
Replace them.....
maxnine11 05-21-2004 11:23 AM
a TSB from 25 years ago says its OK to reuse:
EDIT: note- this TSB refers to 1978 and later !!!!
http://forums.pelicanparts.com/uploa...1085163782.jpg
kqw 05-21-2004 11:28 AM
Does it say from 1978 on? I am assuming these are model years. I believe we're talking about a 1971
ChrisBennet 05-21-2004 11:35 AM
I've always replaced the flywheel bolts but if you read your factory manual you won't find "replace with new" until the dual mass flywheels. The dual mass flywheels used much longer flywheel bolts I think.
-Chris
maxnine11 05-21-2004 11:35 AM
kqw, you are correct, i didn't read the model year in Poorsche Man's signature. Sorry.
i'll edit my original post .
max
kqw 05-21-2004 11:38 AM
No problemo....Max.....
