Where is the VIN # stamped on the engine?
Why would there be a 6,200 RPM Tach in a supposed '71 s? It should have the 7,300 RPM tach. What would be the reason other than the engine being swapped out. If it is an S engine with the 6,300 tach could it be due to having carburators and not mechanical injection? Thanks
'71 911 s Targa |
The VIN is not stamped on the engine. The engine number is on the right hand crankcase, on the vertical casting adjacent to the alternator shroud. The engine type number is on the horizontal part of the right hand crankcase close to the engine number.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
I see 911702 and 6311829. What do these tell me?
thanks
'71 911 s Targa |
According to the Stoddard parts manual, you have a 71S engine. The first number should be 911/02 for engine type. 631**** is the correct sequence for 71S engine serial numbers.
What color is the engine shroud? I know later Esses have red shrouds so I think you should as well. Sounds like you have the wrong tach.
Neil '73 911S targa |
Okay good. The tach had me wondering there for a bit. I don't know why someone would have put a different tach in my my car. Should the carburated cars have the same redline as the mechanical injection cars?
'71 911 s Targa |
Gon fix it with me hammer
red book says it's an S engine
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
'S' tachos sell for a lot more than 'T' tachos.
It could be that the PO had a problem with the tacho & replaced it with a cheaper (& more readily-available) T tacho whilst he had the original rebuilt. |
redline the sucker
if anybody asks > just say , it's a Porsche , it can handle it. ![]() don't mention the tacho background...
