just a quickie....
interior going back into the 73RS after paint....headliner done and carpet will be shortly. My glass guy needs to order the front windshield rubber. What windshield can I use in the car that doesnt require the metal trim strip...is it a 964 windshield? I have been told that some people have re-used their old glass, but you end up with a poor fit, and it is recommended that you use the correct glass with the correct rubber. Also, what about the rear glass....can I use the newer trim-free rubber with the old glass as my electrics for the rear window defogger would be different.
Old 05-24-2004, 08:25 AM
Supposedly you need the 964 windshield and gasket
Old 05-24-2004, 08:50 AM
Is the combination of the old glass and 964 rubber too tight? Or is it too loose? Any thoughts on the rear glass and rubber too? I want to make only original mistakes here...
Old 05-24-2004, 09:04 AM
C'mon guys....somebody must have done this before....I don't want to be the guinea-pig .....and I don't want to end up owning a broken windshield!!
Old 05-24-2004, 02:22 PM
