Question fuel filter in tank of 72 T
My 72 911 T sometimes stops running while driving and then it won't start until several hours later. Fuel starvation? What do you think, is it a bad fuel pump or could the filter in the tank get clogged stopping the fuel. Does not happen everytime I drive the car but when it does it's a pain. How do I check the filter in the tank? Any other ideas? Thanks
Old 05-21-2004, 08:00 PM
Regenerated User
72doug2,2S's Avatar
This is scary, I'm having the same thing happen on my 72'.
Do a search on "MFI Fuel starvation" It will give you good info on this.
I haven't attacked my problem yet, but my guess is that it's the in line from the tank being gunked up.
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law.
'72 911T 2,2S motor
'76 BMW 2002
Old 05-21-2004, 09:25 PM
project 911's Avatar
Not sure if it is the same as on my 71, but there is a brass screen filter that is attached to the fitting that screws into the tank. This is where the gas line connects to the tank. Pull the fitting and you will get the filter. Check the steel hose sections too. They tend to get stuff like concrete built up in them. Be careful under there.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 05-22-2004, 05:06 AM
I did the MFI search, Guess I should have done that first. Lots of great info. I think I'll start in the tank. Thanks for your help.
Old 05-22-2004, 09:55 AM
