Din HP is indeed ( slightly) larger than SAE HP....therefore requiring "fewer" of these DIN HP for the same output motor power.
---Wil |
Wil, All kidding aside, 1 HP= 1 HP. DIN and SAE just use 2 (slightly) different measurements on the motor, ie. one measures w/ all accesories hooked up, one doesn't, or something like that. I forget.
The DIN figure will be higher than the SAE figure for the same powerplant, as evidenced by Porsches #s for 911s. The 2.4 911S was rated 181 SAE net HP @ 6500 rpm by Porsche, and I believe 190 DIN HP. (Source: The Porsche Family Tree , 1983. Official factory literature). :cool: |
well according to Porsche.com
here the 911SC from 1980 is went from 180 to 188, and then in 1981-1983 it was 204 hp... http://www3.porsche.com/40years/pcna/common/modell_lang_6_gen_1_n_11.htm |
This didn't scan very well, but here are official U.S. specs from Porsche factory literature showing all of the SCs @ 172 SAE net HP, 1978-1983: http://forums.pelicanparts.com/uploa...1085425318.jpg |
hey did you notice in the lower right hand corner of the document schuey posted? seems that it came from the horses, eerr porsches offical web site, a SC is a super carrera..
seems like that one can be put to bed finally.... |
| All times are GMT -8. The time now is 07:41 PM. |
