87 911 power seat problems
On my drivers power seat when I try to adjust it forward or rearward only the left side rail adjusts. The right side stays stationary. Any thoughts?
Old 05-22-2004, 11:26 PM
Two of my driver side switches did not work. I opend up the switch. Cleaned off the burned contact with sandpaper. Now both switches works like new. You should try that before replace them.
Caliber
1987 911 Cabriolet
Old 05-23-2004, 12:23 AM
Diss Member
Quicksilver's Avatar
The motor for the seat is in the bottom front of the seat and it has a cable coming off of each side of it. Inside of the cable is a square ended drive cable. It has slipped out of either the motor side or the seat rail side. If you get it re-seated it will immediately start to work.
BTW- Make sure the other side is in the middle of its adjustment before you hook up the loose side. Otherwise it will be operating under a constant binding load.
Wayne
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-23-2004, 05:50 AM
I will try that and as far as getting the seat in the middle of its adjustment. I did not think of that, muliple minds are always an asset. Thanks for the reply, Johnny O
Old 05-23-2004, 08:01 AM
Your the man, I found thhat the cable had slipped out of theseat rail side. Upon inspection it seems to me that if the outside plastic sleave were shortened 1/4 to 3/8 of an inch the likelyhood of the cable slipping out again would be diminished. I'm not too concerned with it because the fix was easy enough. Thanks again, Johnny O
Old 05-23-2004, 10:47 AM
