on-ramp's Avatar
Vibrating fan belt.
Just reinstalled everything after some alternater work. I got the alternator in the same position it was before i took it out.
and placed the 3 shims inside, 3 shims outside, same as before.
but now, the belt is vibrating only on one side (the left side) at idle speed.
what gives?
thanks.
Old 05-25-2004, 06:56 PM
one of gods prototypes
bell's Avatar
sounds like it's a little loose.......belts can stretch, or maybe the alternator housing is sitting in it's "perch" better (did you clean anything up?)
reshim it so it's tighter IMO
Brought to you by Carl's Jr.
Old 05-25-2004, 07:28 PM
I'm not here.
K. Roman's Avatar
Is your alternator tightened down on the fan evenly?
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 05-25-2004, 08:05 PM
on-ramp's Avatar
yeah, it's tightened down evenly.
and i did clean out some dirt that's been sitting after all these years.
i currently have 3 shims inside/3 outside....how do i make the belt tighter?
Old 05-26-2004, 08:20 AM
Move another shim to the outside.
Old 05-26-2004, 08:52 AM
Somatic Negative Optimist
Gunter's Avatar
Is it a new belt? Feel how tight it is by pressing the belt with your thumb halfway between the two pulleys, the belt should move in by about half the thickness of your thumb. A rough estimate. Too tight means a load on the Alt/Fan bearings. Too loose could be possible slipping of the belt when Alt output is needed for A/C, lights, wipers,etc. Make sure that the pulley halves align when tightening the nut. Don't just stick something into the fan to hold it, use the proper special wrench to counter-hold the fan. Less shims on the inside means tighter belt.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-26-2004, 09:08 AM
on-ramp's Avatar
no, it's an old belt.
but i found out the problem, the 3 outer shims were not sitting properly over the shaft....they had fallen off and as i was tightening the nut, they got crushed and distorted, so the fan belt was not as tight as it should've been.
I actually had to Scoth tape the 3 outer shims together (after banging on them with a hammer to flatten them) to get them to stay on there properly while i secured the nut. did the trick. no more vibration. everything is back to normal (for now).
appreciate your input
Old 05-26-2004, 06:51 PM
bell's Avatar
glad you solved it, over time that may have cause problems
Old 05-28-2004, 04:50 PM
Senior Member
john_colasante's Avatar
Anyone who hasn't squashed those shims and had to hammer them flat is lying or has never changed their fan belt.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 05-28-2004, 04:52 PM
on-ramp's Avatar
thanks...i'm usually very picky about little things that dont look quite right on my car....like a vibrating belt.
sloppy work is recipe for disaster.
Old 05-28-2004, 06:48 PM
