-   -   tire size option 85 carrera (http://forums.pelicanparts.com/porsche-911-technical-forum/164570-tire-size-option-85-carrera.html)
dfink 05-24-2004 03:46 PM
Tried to do a search and found lots of interesting tire size discussions but nothing that really directly answered my question. I have an 85 cab that had on it 15X7 and 15X8 fuchs when I bought it. I assume they are stock but not for sure. I don't have the owners manual. Question is was that a stock size for that year and was there an option for 16X7 and 16X8. Trying to figure out how big I can go and stay stock.
Bill Verburg 05-24-2004 03:50 PM
7&8x15 was an option. 7&8x16 was not.
But 7&8 or 7&9x16 are fine choices for an upgrade, 205/55 and 245/45 would be the best tire choices for least hassle.
dfink 05-24-2004 04:00 PM
Thanks for the answer.
stone43 05-24-2004 04:20 PM
Dfink,
I have the same car with the same wheels and am looking for tires right now. Tire Rack has the best selection. They do have 245x50x15 for the 8's and a 225x50x15 for the 7's up front, made by Dunlop (SP8000), Z rated, decent reviews, not outrageously priced.
I am personally trying to get as much rubber on the road as possible, hence my search for 245's. 225's are easy and there are many more choices.
I am in the same dilemma, buy new tires and stick with the 15" Fuch (which I recently had polished out by Al Reed and they look great) or try to find new wheels.
Bill Verburg 05-24-2004 04:23 PM
245/50x16are too tall for use w/stock gearing, you'll be sorry if you use them.
stone43 05-24-2004 04:56 PM
What do you mean Too Tall?
stone43 05-24-2004 05:02 PM
Bill, my goal is to get the widest possible tire i can. Since they are only 15 inch rims, i don't want to go too low on the profile, or it will look stupid. I have been searching for the perfect solution, even if I have to add spacers, I will. I just really like the wheel wells filled out to the max without having to roll the lips.
yelcab1 05-24-2004 05:06 PM
Humm, I remember my 84 Carrera came with 16 inch wheels and tires from the factory with a sticker on the car. 225-55-16 is the rear ones.
Bill Verburg 05-24-2004 05:13 PM
225/50ZR15
23.9" height
881 revs/mi
881 height
245/50ZR15
24.7"height
848 revs/mi
The more significant figure is the revs/mi you will not like the change from the 225/50 to the 250/50
225/50x16 on 7s was an option on '84 Carrera, 225/55 x16 was not.
Mark Wilson 05-24-2004 05:13 PM
Two different sets of 16x7/9's with 245/45 and 205/50's.
http://forums.pelicanparts.com/uploa...1085443795.jpg
http://forums.pelicanparts.com/uploa...1085443959.jpg
stone43 05-24-2004 05:16 PM
Are the 245's on the top picture? Those look really good.
Mark Wilson 05-24-2004 05:24 PM
Both are 245's. The top are RE730's and bottom are Pilot Sports (now on Drago's car).
stone43 05-24-2004 08:21 PM
So does (or has) anyone ran some 245's on 8X15?
yelcab1 05-24-2004 08:29 PM
That is right, it was 225-50 VR 16 on the rear, and 205-55 VR 16 in front. Don't have the car anymore and apparently, gone too is my memory.
sdusablon 05-25-2004 12:49 PM
I'm interested in the answer too because I also have 7x15 & 8x15 Fuchs on my car. I've been looking to upgrade to 7x16 & 9x16 but they command quite a price right now.
As a result, I've been wondering what is the largest tire I can fit on my current setup.
dfink 05-25-2004 12:51 PM
Thanks for all the input. I have two sets of wheels. 15 7+8 and 16 7+8. Hoosier makes the a3s04 in 245-50-15 and 225-55-15 hoosier lists the wheels as 8" for the 245 and 7" for the 225. I think I will give these a try for autocross. They will be much smaller diameter than what I have so I hope they don't rub. I currently have 225 and 205 don't remember the aspect ratio (i think 45 and 50) on the 16" wheels for the street. Toyo T1S work really well.
masraum 05-25-2004 01:10 PM
Well, you can fit a 275 60 15 on a 15x8, but that would be horrible. I've also heard of people getting a 295 50 15 on a 15x8, but that's even worse.
Well, there is a 275 50 15 and a 265 50 15 that will both fit on a 15x8 BF Goodrich Radial TA. Of course, I think all of these are a bad choice.
I'd stick with the 225s or upgrade to 16's, but do what makes you happy.
stone43 05-25-2004 08:26 PM
I can see where 275's or 295's seem a bit extreme.
I see ALOT of 245's on 16" rims, why not on 15's??
Kahuna 05-26-2004 03:59 AM
I think it may be that there are few 9x15 wheels which better suit the 245 tires. Most of the 245/45x16s are on the more common if expensive 9x16.
SLR 05-26-2004 06:01 AM
My 85 Carrera Euro Sport left the factory with 225 50 16 R and 205 55 16s F and I'm wanting to put 17s on soon
Steve.
