Slumlord
Porsche_monkey's Avatar
75 911 S Timing
Is 5 degrees ATDC @ 900 rpm correct for 75 911S-CIS?
(advance is disconnected permanently).
Old 05-25-2004, 10:21 AM
Slumlord
Somebody must know.....
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-25-2004, 02:59 PM
Alan Cottrill's Avatar
I set my '77 at 35 degrees BTDC @ 5500 rpm.
someone correct me if I'm wrong, but on the 75-77 2.7 cis cars isn't it a vacuum retard on the distributor?
big AL
'77 911
Old 05-25-2004, 03:47 PM
due to smog in days of old more than one setup cam from the dealer.. I had the Calif stupid system, w/ same dizzy as everybody else.. I had great results w/plugging the vac hose and setting to Zero.. confirm the total at about 33-35deg, gas sucks in NY.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-25-2004, 08:24 PM
Slumlord
So about 0 degrees at idle, 33-35 at 5,500?
I'll try that today. I was not aware of the 5,500 rpm setting, I just rebuilt my engine, but I guess I need to do that.
Dwell angle anyone?
84 Cab - sold!
Old 05-26-2004, 06:25 AM
Dwell angle anyone?
Try it.. I dial in in 2deg increments.. depends on situation;
mountains, deserts, oceans.
Bosch dizzy- '76-'77 Tech Spec text.
38 +-3deg
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-26-2004, 07:54 AM
Slumlord
Thanks.
84 Cab - sold!
Old 05-26-2004, 07:55 AM
