Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Weltmeister Cambermeister question
Rumor has it that the Cambermeister can give you one more degree of negative camber than you can get in the stock configuration...any truth to this? And, if so, is it the one that is $199?
Thanks all.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 05-19-2004, 01:13 PM
Senior Member
Jdub's Avatar
Any strut bar can provide some degree of overcamber I *think*. I would concentrate on which bar mounts most effectively to the strut uppers.
I went with Chuck's Elephant brace (very pleased) but I was not in the market to get negative camber so YMMV.
John
'78 Targa in Minerva Blue
Old 05-19-2004, 01:38 PM
Rennch on YouTube
rennch's Avatar
I *am* in the market for more negative camber, so this cambermeister brace looks like a cost-effective option if it does indeed add a bit more. I guess we'll see!
Thanks,
mike
Michael O'Neal -
Old 05-19-2004, 01:42 PM
Any strut bar that bolts onto the strut towers and has threads to adjust the spread can create negative or positive camber. It's just a matter of reducing the span with a wrench to draw in the towers. Careful, not too much. I'd consider doing this only as a fine tuning adjustment.
A better way to gain more camber range is to remove the strut and enlarge the mount opening in the chassis with a rotary grinder or equivalent. Careful, not too much.
Sherwood
Old 05-19-2004, 04:17 PM
Rennch on YouTube
rennch's Avatar
Unfortunately, Sherwood, my class doesn't allow that. So I have to get the max camber without enlarging the mount opening. I can slot the mounting holes, but can't enlarge the main opening. So, my original question remains...can I get MORE by using the Cambermeister?
Michael O'Neal -
Old 05-19-2004, 07:55 PM
Chuck Moreland's Avatar
Like Sherwood said - any left/right threaded strut brace can be used to pull the towers together. But only a little, you might get 1/8-1/4 degree before you close up your hood gap completely. This isn't a way to achieve significant camber increase, and you have no control over the impact to each side - it may not be equal.
Your options for more camber -
- sloting the mounting holes
- offset camber plates
- weld-in camber boxes
- decambered spindles
- an entirely new product I'll be announcing this summer
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-19-2004, 09:33 PM
Az911's Avatar
Send a message via AIM to Az911
The Wevo camberking says it will get you 1 degreee more camber with out chassis mods. A little pricey at $700 but it comes with front mono balls also.
72T RS look
96 993
Old 05-19-2004, 09:38 PM
Automotive Monomaniac
Emission's Avatar
I've got one on my car, and it does appear to allow you to crank in some negative camber. I'd be wary of this approach, as you are mechanically pulling on the shock towers and tweaking the "natural" setting of the chassis. I'd only do this for minor adjustments too (mine is just "tight" - not cranked down).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 05-19-2004, 09:48 PM
Rennch on YouTube
rennch's Avatar
Ok...that might be what they claim is the 1 degree
Thanks.
Michael O'Neal -
Old 05-24-2004, 03:30 PM
Actually the cambermeister will give more camber by crushing the rubber bushing on the upper mount. The front shock bar itself goes through a hole in the cambermeister plate and "replaces" the function of the rubber bushing. You then have direct control over where the top of the shock is located and can move it in quite abit. The limitation on my car is under the fender where the dust cap for the strut hits the inside edge of the fender.
-Andy
Old 05-24-2004, 08:27 PM
Noel's Avatar
Come on Chuck, give us some idea what you have cooking? SHould I delay my purchase of a triangulated brace from you or does this new product not incorporate a different brace setup?
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 05-25-2004, 04:09 AM
Rennch on YouTube
rennch's Avatar
How much do you suppose I'd get by slotting the mounting holes? It seems to me that if I could reduce the size of the top bushing/nut, and slotted the mounting holes, I could get a whole bunch. And what are "offset camber plates" Chuck?
Michael O'Neal -
Old 05-25-2004, 07:52 AM
