geof33's Avatar
steps to take after stripping...
Getting my steel 69 fenders and having them media blasted in the next couple of weeks. The question is, what are the bare metal steps to keeping rust at bay? It will probably be 4-5 months before I'm ready to paint... Never dealt with new bare metal so I'm not sure. Did a search and found some bits and pieces, but not THE thread...
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 05-27-2004, 06:35 AM
Air Medal or two
afterburn 549's Avatar
maybe wait 4/5 mo b4 striping??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 05-27-2004, 07:14 AM
geof33's Avatar
I thought about that. The problem is the flare addition. I'd like to get that done asap. I guess ultimately the question is strip pre-flare or post?
GruppeB #935
95 Dodge Ram 2500
03 Toyota 4runner
Old 05-27-2004, 08:07 AM
Somewhere in the Midwest
MotoSook's Avatar
If you are getting it stripe eventually, weld the flares on, then seal the bare meter with a coat of paint from a rattle can...it'll seal it well enough, then the blasting will remove the paint...undercoat the backside after you clean the surface witha wire brush (on a drill works good). The seam rust instantly when you weld, so you better clean it before you seal it.
Old 05-27-2004, 08:15 AM
72 four door's Avatar
After it comes back wipe it down with prep sol and shoot it with either epoxy primer or etching primer. thatll hold it at bay
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 05-27-2004, 08:23 AM
echrisconnor's Avatar
I'm certainly no expert, but asked the same question a few months back on the AutobodyStore.com forum. I got a bunch of recommendations for Picklex20. Apparently very easy to spray on and wipe off.
http://autobodystore.net/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=RCAC
'76 911 Carrera 3.0
Old 05-27-2004, 08:29 AM
Just spray with WD40 and wipe off the excess. If you bag them in plastic and store indoors they'll stay good for a vey long time.
Just clean them properly with Prepsol before fiiting them to the car and starting the bodywork. I had some shhetmetal sotred that way for 5 years and it still looked new.
Old 05-27-2004, 11:34 AM
