-   -   My jerry rigged brake cooling system actually worked... (http://forums.pelicanparts.com/porsche-911-technical-forum/164900-my-jerry-rigged-brake-cooling-system-actually-worked.html)
alf 05-26-2004 02:37 PM
Finally had a chance to test out my budget brake cooling system on the track yesterday. Happy to report that after 100miles of track driving, i experienced no fade. Ambient temps were about 60F.
Here is what i did.
1-Removed the factory dust shields
2-Installed Smart Racing Hub block off plates
3-Jerry Rigged the factory 993 air deflectors to fit my 88.
4-New Zimmerman cross drilled rotors all around
Prior to doing this, i was experiencing significant fade at the track.
Some pictures of the set up before i removed the dust shields...
http://forums.pelicanparts.com/uploa...1078419359.jpg
http://forums.pelicanparts.com/uploa...1078419374.jpg
http://forums.pelicanparts.com/uploa...1078419385.jpg
masraum 05-26-2004 02:45 PM
Good to hear it.
alf 05-26-2004 02:54 PM
double posted...
Elombard 05-26-2004 03:08 PM
Cool
What did that cost??
For the deflectors and Smart racing parts I mean.
Elombard 05-26-2004 03:09 PM
Looks like those deflectors could be cut out of sheet plastic pretty easy??
Night give it a wack!
ChrisBennet 05-26-2004 03:19 PM
What's with the stickers? That's extra weight man! :D
-Chris
atlporsche 05-26-2004 03:24 PM
eric!!!
remember, I have a vac forming machine at work!!!
the stickers add more braking force...
sjd
MichiganMat 05-26-2004 03:53 PM
Heres another neat and cheap way to cool your brakes like a pro:
<img src=http://www.tty1.org/~prophet/mypics/PorscheTips/brakeCooling1.jpg>
Just use the stocker dust shields and cut a big hole in it. Pair it up with some ducts from IOPort racing and you're set.
jrdavid68 05-26-2004 04:22 PM
I thought stickers made cars go faster.
alf 05-26-2004 04:41 PM
Backing plates were $50 from Smart Racing, not sure if Pelican sell them. The 993 deflectors were under $40 from Porsche, they are reinforced in the back and have a scalloped design, probably difficult to duplicate from sheet plastic. Took about an hour or two to install.
The hose method would probably offer better cooling but was a little bit more involved. Would have gone that route if the 993 set up did not work.
alf
Jim Smolka 05-26-2004 04:42 PM
Stickers make one's 911 go faster only if they are on the outer sheetmetal. :D
Emission 05-26-2004 06:08 PM
What's the Porsche part number on the deflectors (I assume there is a LEFT and RIGHT)?
Are there deflectors for the rear too?
alf 05-26-2004 07:25 PM
I just went to the local Porsche dealer and asked for the 993 brake air deflectors. I'll see if i could find the reciept, the sticker is no longer legible. Yup, left and right. No deflectors for the rear.
alf
Emission 05-26-2004 09:39 PM
alf
No drilling on the vehicle, right? It looks like you just made some holes in the deflector. Do you have any pics of the other side?
How do you keep them from spinning around on the suspension arm?
Emission 05-26-2004 09:47 PM
I think these are the part numbers (I found them on an NSX site - they use them in the aftermarket for brake cooling too!):
"The parts in question are Porsche #993-341-083-00 (left) and 993-341-084-00 (right)."
alf 05-26-2004 09:50 PM
No drilling. There is a horizontal rib in the back of the deflectors that will rest on the A-arm. Just zip tie it tightly and off you go. Be sure to remove the factory dust covers though.
alf
}{arlequin 05-26-2004 11:37 PM
--that way you can show off to everyone on ebay that it's OEM!:D :D
Emission 05-26-2004 11:39 PM
I'm going to paint "RUF" on mine! :D
atlporsche 05-27-2004 04:48 AM
they do, but these are on the brakes...
brake stickers make cars slow down better...
sjd
thrown_hammer 05-27-2004 07:18 AM
What do the Smart Racing hub block off plates look like? Do they have a website?
