Britain Smith's Avatar
The "ultimate" cage/rollbar thread
I am going to be putting a cage in my car next week and I wanted to get some ideas. If you have pictures of the cages or rollbars, bolt-in or welded-in, through the firewall, etc. post them here please.
This picture is not my car, but exactly what I want to do in the engine bay, through the firewall...
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 08-31-2004, 01:25 PM
Come on guys...give me some ideas.
-Britain
Old 08-31-2004, 03:26 PM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
me likey pretty pictures
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 08-31-2004, 03:38 PM
Britain, I did the cage in your first picture. PM me if you want some more info, I do this as my business.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 08-31-2004, 03:40 PM
i would check the rules of your race series first - most will specify mounting arrangements and many do not allow suspension points to be tied into the cage
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 08-31-2004, 03:58 PM
Here is a pictue of the front area of my track car cage. It is stitch welded to the side of the tub and is fully welded to the suspension pan, above the suspension mount areas. It is made from 1.5" .095" DOM which is the SCCA and PCA requirement for cars under 2,500 lbs.
Good luck !
Old 08-31-2004, 09:23 PM
Awesome Cage design James...
I really like the way that you attached in the rear suspension points. I am going to get a rollbar welded in and I am probably going to go through the rear firewall to the framerails like you did. I couldn't decide if the crossbar should attach at the framerail similar to the pic below or if it should just go to the firewall like your cage above. Any ideas?
-Britain
Old 08-31-2004, 09:29 PM
Britain,
In regard to your crossmember, it depends on the motor you are using. It might cause an issue with intake components if run as shown in the picture. Please remember that a cage should be welded with the car loaded on the suspension points to alleviate as much post welding stress and distortion issues as possible. Ryan also made an excellent point regarding series rules. The PCA rulebook is pretty straigtforward wheras the SCCA one is like reading leagalize. They mention tube thickness and diameter and after that it's very class dependent. Please feel free to e-mail me offline with any other questions you might have. I have run some FEA for different Porsche models and have a good baseline of where to start.
Remember too that one of the most important aspects of a well constructed cage are the welds. Make sure that your fabricator is a certified welder and is familiar with joint design as per AWS( American Welding Society) codes.
Cheers, James
Ayrton Senna
1993 964 RS
Old 09-01-2004, 06:30 AM
