Unregistered
sammyg2's Avatar
broken head stud pictures
link to thread on rebuild forum, can't double post:
I must be the luckiest SOB on earth
Old 08-31-2004, 08:42 PM
GettinHeadStuds's Avatar
Thanks for that info...
I found a broken head stud and rebuilt the same week, b/c of the fear of doing more damage... Hmmmm....
Question:
In the following picture, is the black goop/stain around the middle cylinder caused by the hot exhaust fumes that may have seeped out of the cylinder with the broken stud?
83 SC (gone) / 72 T (gone)
Old 08-31-2004, 09:15 PM
Would someone mind circling the broken stud in the picture above? i've never seen one before and curious as to how to identify one.
-Ian
Old 08-31-2004, 09:17 PM
You can see it in this picture.
Old 08-31-2004, 09:21 PM
jwhcars's Avatar
Click on the link in the first post and you will see the broken stud.
2 - 75 914 Sold 76 912E Sold
81 911SC Sold 05 Boxster Sold
06 Cayman S Sold 14 Cayman S
14 Explorer XLT DD
Old 08-31-2004, 09:22 PM
ah, many thanks.
Old 08-31-2004, 09:23 PM
Unregistered
sammyg2's Avatar
yup. it is gummed up a bit around the broken stud, but no evidence of any other leaking or metal damage.
I must be livin right.
I bet if that broken stud was on the end instead of the middle things would have been different.
Old 08-31-2004, 09:53 PM
if you glass bead the mating surface, i bet you'll see some irregularities that should be machined for a proper seal. the center ones have more support for sure, but the black areas are from exhaust leaking out, so the head was lifted off the cylinder every time the charge fired off.
206 637 4071
Old 08-31-2004, 10:35 PM
Unregistered
sammyg2's Avatar
OK, I'll betcha a beer
Old 09-01-2004, 01:45 AM
Thanks for posting this over here, I don't get to engine building threads very often.
Old 09-01-2004, 05:54 AM
