Black and Blue
cant wait for the next round of pics...
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
WERK I,
Thanks for that bit of info, I was wondering if that was the reason for the differance. I did my Carrera as close to the "later" factory style with a Mocal cooler and aftermarket fan. Certainly made the plumbing relatively easier. And I like the look of the factory steel valance better. Keith Epperly-87 slant nose turbo look carrera cabriolet |
Feeling better yet? Maybe he should lay off the cigars....
Audi B7 S4 |
bump, need more info, more photos
That tail rubber is not happy.
Warren & Ron, may you rest in Peace. |
Black and Blue
nice...progress...love it.
Any pics of the tuna? Hope he didn't put the cigar down during the fight!
Audi B7 S4 |
Montana 911
good to see you guys back in action.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Savagery to tuna as well as tin. Will it never end?
Please end that poor 911's suffering.
'72 911 T/E Silver Targa |
I remember, back in the day, when those turbo-look slant-noses were really cool. Well, it's only a Targa!
Buy them, sell them
Thanks for keeping us in the loop on this project. I've been watching with interest!
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
Glad you are back! And thanks for the thread.
1977 911S 1973 Alfa Romeo GT Veloce 1997 Lotus Turbo Esprit V8 2016 AMG C63S |
A post like this can't be beat! Unfortunately, it looks very easy in the pictures, but I would be nuts for trying (and wouldn't). Very cool post! This is one for the archives.
-kb- |
Someone explain "peel and weld"
-kb- |
Automotive Monomaniac
I am pretty naive about bodywork.
After the peel and weld, do you use filler (Bondo?) to fill the gap? What happens next?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Emission,
There are a couple of different, yet similar, techniques for doing this. To answer your question, while you "trace cut" there will be a gap between the new flare and the existing body panel, in this case the upper quarter panel. As you progress this gap is spot welded, an inch or two apart, to hold the new flare in place. When the entire flare is spot welded in place you can remove the old flare from within the wheel well. The spaces between the spot welds can then be connected using the butt welding technique. This is typically done on an alternatining basis to prevent heat build up in a small area which will create warping. Hope this isn't confusing.
jeeze is there enough Bondo on the welded on fender??? looks like a lot. interesting, i have never seen this done before, very cool its being put up for show and tell.
74 911s neverending story. two feet and a jetta for now. |
Very nice, and it's 100% steel. Cool.
Sunset, I sort of familiar with the concept of shrinking, but what would be the result of not"wet ragging" it? Does shrinking smooth the surface more or is it a stress-relieving measure? Thanks for the effort in posting this project!
The use of Heat and a Wet rag are to shink the metal. After using the Hammer and dolly to shape the metal. It is not necessary to Heat and hit with the Wet Rag.
You can use filler to get the surface smooth, We like to use as little filler as possible that why we use the Heat and wet rag to shink the metal. |
