Correct fuse values
Hi all-
I just rebuilt my two fuse boxes (up front) in my 71T and found that the amp ratings on the fuses are all over the place. Clearly PO's had replaced fuses with whatever thay had around. One turn signal would have an 8 amp, and the next might have a 25 amp, etc., etc. Does anyone know where I can find a chart that tells what amp fuse should go in what locations? I have plenty of info on what each location is for, but not what amp should be there. Thanks fo any help. |
Haynes Manual, page 193 has the following chart for 70-73
Box 1, (top) 1 - 5 2 - 16 3 - 25 4 - 16 5 - 16 6 - 25 7 - 25 8 - 16 9 - 5 10 - 5 Box 2 (lower) 1 - 8 2 - 8 3 - 8 4 - 8 5 - 5 6 - 5 7 - 5 8 - 16 Box 3, (engine) 1 - 5 2 - 8 3 - 25 Pat |
Bingo!
Thanks Pat. Just what I needed. I appreciate it. |
| All times are GMT -8. The time now is 01:21 PM. |
