-   -   Bulk ignition wire part number? (http://forums.pelicanparts.com/porsche-911-technical-forum/165171-bulk-ignition-wire-part-number.html)
Shakenbake 05-28-2004 07:49 AM
Hi guys, long time no visit. I've been a bad boy and left my 1974 911 sitting for too long. I'm in the process of rebuilding ignition wires, all beru connectors have been tested and seem to be +/- 10% of each other. The wires have dried out and are inconsistent with regards to readings. I've searched all previous threads over the past few days and I'm specifically looking for a NAPA auto parts number for 7mm Solid core bulk ignition wire manafactured by Belden. It seems that there are many types and I'm just looking to simplify the process, Thanks
stlrj 05-28-2004 08:00 AM
Resistance values of your Beru connectors and continuity of your wires will tell you nothing as far as their ability to conduct secondary voltage to the spark plugs without shorting to ground. The only thing the voltmeter does is give you a false sense of security as to the condition of your cables and connectors.
Cheers,
Joe
