jeff1hughes's Avatar
fuel smell under hood?
OK, I just opened my hood (front) and I now have a strong scent of gasoline. It is an 86, and don't really know what it could be. Then again, I haven't really looked yet. Is there an evap system that goes to the front of the car (I know my 71 had a vapor can in the trunk)? Any help here would be greatly appreciated.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 11-04-2004, 08:38 PM
I have the same problem. Especially if I fill the tank. Cure has been don't fill the tank. I have replaced all the hoses and the problem persists. Hope someone has some suggestions. The over flow tank seems fine so I guess I should check it out again.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 11-04-2004, 08:52 PM
I had a smell of gasoline that began to get stronger. Eventually, I could smell the gas while driving with the window down. I replaced the hoses in the front compartment and still had the smell. I removed the plate covering the bottom fuel pump and could see that fuel was leaking where there the rubber fuel line was fitted to the steel line going to the engine. There have been some recent posts on replacing this line.
There is one fairly recent and also check this out:
Replacing pressurized fuel line from pump on 78 SC?
82 911SC
Old 11-05-2004, 07:43 AM
304065's Avatar
It's probably the cork fuel tank gasket.
964's have another problem, where fuel sloshes out on hard cornering (not that I ever did THAT). . .
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-05-2004, 07:54 AM
Steeve's Avatar
Try replacing the gasket around the fuel level sender. It's a cheap fix, and I think that's a pretty common source of your problem.
'86 911 targa
'04 MB 230K Sport (daily)
Old 11-05-2004, 08:00 AM
I would rather be driving
jpnovak's Avatar
mine has a fuel smell too. Its the new cork sender gasket. I think I will have to cut my own from some rubber sheet.
Old 11-05-2004, 09:14 AM
I will check out the gasket. By the way, I was able to buy a rubber gasket for my old car at the local NAPA store one time. It's listed for their universal fuel sender. Maybe this can save you some cutting! If I remember correctly it even had the proper bolt pattern, seeing as the bolts aren't spaced equally around the sender.
Old 11-05-2004, 10:52 AM
speedman's Avatar
gas smell
I had the same problem in my 79 SC and found that the outlet hose on the fuel pump had a small hole in it. I fix the hole and the smell disappeared.
Rick T
Old 11-05-2004, 11:55 AM
Stay away from my Member
campbellcj's Avatar
Also check the seal on each end of the big filler line.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 11-05-2004, 08:15 PM
