Question What is a 105k mile 1982 911SC engine complete worth?
What is a 105k 911SC engine worth? (1982)
I'm thinking about installing a 3.2 or 3.6 engine in my car.
So if I sell the 911SC engine it would be complete with wiring harness, lambada box, muffler to air cleaner, clutch & flywheel (but without the a/c compressor).
The engine has no leaks, runs good, and just had the valves adjusted, new plugs/wires/dist cap/rotor and new fuel injectors.
Clutch was replaced at 95k miles.
And it doesn't smoke hot or cold (not on startup either... no puff).
Thanks... I'm trying to decide if I'm going to proceed on this project.
TonyG
Old 05-06-2004, 10:51 AM
Tony, providing compression and leak down stats will go a long way to maximizing your profit....if they're good #s.
If I were in th market I'd love to see the engine running. If you have to remove take a video of it running (cold start, run, rev, stop, warm restart) for potential customers to view.
Warren & Ron, may you rest in Peace.
Old 05-06-2004, 10:58 AM
Me like track days
Craig 930 RS's Avatar
Sold my 151k 911SC Euro engine for $2800 - no exhaust.
Buyer got a bargain.........
Craig
@RS
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 05-06-2004, 11:18 AM
Team California
speeder's Avatar
Craig
@RS
I would agree w/ Craig about the bargain, that's on the low side for a tight motor. That's a fair price for a complete SC motor needing a rebuild.
Denis
Old 05-06-2004, 11:24 AM
rfix'n's Avatar
My '78 had about 200k miles, leaked a fair amount of oil but started and ran great. Buyer got to see it run in the car and had the option of taking it for a test drive. $3k.
Rob Fix
'78 3.6L SC Targa
Eiche Gruen Metallisch
Old 05-06-2004, 12:23 PM
Me like track days
And my engine had the Carrera tensioners, 3-8% leakdown,
flapper in the airbox...BUT no smoke under any situation once fairly warm.
Craig
@RS
Old 05-06-2004, 12:26 PM
Schuey's Avatar
$4500
1992 964 C4 Coupe (black/black)
1982 911SC Coupe (lt blue met/black)
1965 Mustang Fastback (black/black)
Old 05-06-2004, 01:24 PM
Elombard's Avatar
I would leave it in the car so the owner can drive it. I just sold my unknown miles SC motor. Ran great....but.... leak down on #6.
$2200 - quick sale. I bought Craigs' motor, Can't wait to get it in!!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 05-06-2004, 05:31 PM
Elombard
I've had 3 people so far offer me $3500 for the engine without the Lambada control....
I think Schuey's estimate of the worth is probably pretty close...
TonyG
LSx 951 with 997 Cup Suspension - vision944.tonygarcia.org
3.6L 911SC - www.tonygarcia.org/911SC
Old 05-06-2004, 06:03 PM
Originally posted by TonyG
Elombard
The Lambada control? What control?
You cannot control the urge to Lambada. Its the forbidden dance.
Old 05-06-2004, 06:10 PM
Tony,
If you sell just the engine, I'll buy the lambda brain box with the harness.
Jim
Old 05-06-2004, 06:42 PM
on-ramp's Avatar
Old 05-06-2004, 06:44 PM
A Quiet Boom's Avatar
I'll second the $4500 number, that's what I paid for an 85K motor with a damaged exhaust about a year and a half ago, seems to be about the going rate.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 05-06-2004, 07:03 PM
A Quiet Boom
Did that include the Lambada control unit & wiring harness (if your engine required it..)?
What about shipping? Did that include shipping?
TonyG
PS> I'm just trying to get the engine priced appropriately so not as to waste anybodies time (if I decide to sell it).
Old 05-06-2004, 07:18 PM
Yes it included the lambda box and harness, shipping from CA to OH was another $400.
Old 05-06-2004, 07:36 PM
A Quiet Boom
So if you paid $4500 for your 85k engine with damaged exhaust, then I would think $4500 for one with 105k (with all the stuff) without damaged exhaust and complete new ignition system and fuel injectors should be pretty close to the correct price.
I guess I'm off to the classifieds......
As it looks right now, I'm probably going to buy a 27k mile, 993 Vario Ram motor complete with electronics to install in my '82 SC. I'm just hesitating on exactly how much fabrication (other than the exhaust) is going to be required....
TonyG
Old 05-06-2004, 08:00 PM
Elombard's Avatar
I think you will wait at that price. Well see, you can always lower it. I think you could find a buyer in a reasonable time for $3500. They were not banging down the doors for my motor - admittedly smaller market for one advertised with a leakdown problem... I just think the market has gone to the 3.2 and 3.6. Until about 5 years ago the 3.0s were very expensive. Lets see what happens - good luck.
Old 05-06-2004, 08:08 PM
Elombard
A very good friend of mine owns a Porsche dismantling shop here in Los Angeles, which sells a ton of these motors. He told me that the 3.0 engines are going up in price, as are the 3.2's. The 3.2's are going up in price because it's cheaper to find a 3.2 over what it would cost to rebuild a 3.0 (almost....) and they are a direct swap. But he also said that a lot of people want to keep the 3.0 in their car to keep it original, which is driving the 3.0 market (at least here in Los Angeles).
He told me that while the 3.0 has it's share of problems, the 3.2 also has it's own problems... so both are not trouble free.
My background is in 944 turbos (an extensive background), but I'm just not up on the 911 stuff (although I've owned 2 - 3.2 Carrera's and 2- 3.0 SC's... all were stock except one of the Carreras which was a Euro model that I added a test pipe, fuel controller, and MAF to..).
TonyG
Old 05-06-2004, 08:16 PM
Gordo2's Avatar
Thinking alike
Sounds like you are considering the same approach I am. My latest thoughts are to leave my 3.0 in the car, buy a 3.2 to work on (rebuild/upgrade) and swap it when I have it ready. I plan to do my own work no matter what approach I end up taking.
From recent searching it appears you can get a 3.2 for $5.5-$6.5k. Selling off the 3.0 for $2.5-3k puts my investment around $3-4k, leaving me room to rebuild the 3.2 how I would want it. It also leaves my 3.0 in the car until I'm ready to sell/swap allowing potential buyers to see it running and reducing my down time.
Haven't seen a lot of 3.2's out there though. Most of the major Porsche dismantlers have them, but I would like one that I can get a feel for how well it runs prior to purchasing.
Good luck.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 05-06-2004, 09:09 PM
Gordo2
I've worked on so damn many 944 turbo engines I just don't want to tool up nor do I want to spend the time to mess with doing any engine building... honestly.. I'm tired!
From what I've been seeing here in LA, a real good late model 3.2 complete with <50k miles is about $7500. A "decent" 3.2 with over 65k miles is about $6000, and a non-Vario ram 75k mile engine is about $7,000 and a <35k mile Vario ram is about $8500.
My 105k SC engine is real nice with zero problems and I just spent about $1000 on it for tune up junk (valve adjust, fuel injectors, full ignition replacement). I was planning on selling the car, and infact had a couple of buyers, but since I just bought the car, the DMV had not returned the new title, so the buyers "chickened out" :-) .... understandably so... but now I have the title in hand, but the car is so nice I really want to keep it. However, coming from a 400+ rear wheel HP 944 turbo, I'm missing the "thrust addiction".....
So tomorrow I'm pulling the 3.0SC engine out of the car.....
I just can't bring myself to install a 3.2 engine since being a HP junkie, the 30HP or so the 3.2 would provide just doesn't justify the additional cost.. however the 3.6 vario ram has got me dribbling all over myself as I type this... :-)
ehheehh
TonyG
Old 05-06-2004, 09:57 PM
