Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Off of which model years can I find...?
Hi. Looking for a low-budg suspension upgrade for my 72 911. Can someone please tell me what cars I should be looking at for these parts? I'm going junkyard shopping. (So to speak.)
(ie.. 28mm canooder links are found on the 84 carrera, etc...)
• 21mm F torsions
• 26/7/8 mm R torsions
• Adjustable Spring Plates
• 22 mm F Swaybar
• 22 mm R Swaybar
• Aluminum front crossmember
• Aluminum trailing arms
• 16 X 7 or 8 cookie cutters (to fit early offset...I DO have spacers)
• 16 X 9 cookie cutters (From a 944 maybe?)
That's all I can think of at the moment. If you can think of anything I'm missing, please chime in.
Thanks in advance!
mike
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 05-29-2004, 06:46 PM
Rennch on YouTube
rennch's Avatar
Bump. No one knows any of this stuff???
Come on...you don't have to have every answer!
Michael O'Neal -
Old 05-31-2004, 12:28 AM
Paco Anton's Avatar
Send a message via Yahoo to Paco Anton
Cookie cutters only came in 15" and, AFAIK, only in 6" and 7" widths. They were standard in 1974-83 in many European markets, but most US cars came with Fuchs wheels as an option.
You are probably thinking of Fuchs wheels...
Paco Anton
83 SC Targa (Euro)
Old 05-31-2004, 02:04 AM
makaio's Avatar
Adjustable Spring Plates = 78-86
Old 05-31-2004, 03:58 AM
Pat S's Avatar
• 21mm F torsions (not stock, 18.8 was as big as they went)
• 26/7/8 mm R torsions (75-89 930 had 26s)
http://www.pelicanparts.com/techarticles/911_torsion_bars/911_torsion_bars.htm
• 22 mm F Swaybar (87-89 Carrera, but it has a different connection to the A-arm than you have, you have the throught the body style I think and these are under body. Through the body is generally thought to be better, but you'll have to upgrade to aftermarket style to get anything over 18mm)
• 22 mm R Swaybar 87-89 (Carrera has a 21, but no 22s. you'd want smaller in the rear anyway to keep the back planted though right?)
Used Carrera sway bars - anything to look out for?
Lots of sway bar info about halfway through here:
http://www.pelicanparts.com/techarticles/911_speed_prep/914_speed_prep.htm
• Aluminum front crossmember (75-77 could have either steel or Al, according to the PET it oks like steel went away in 78)
Mid-years front suspension cross-member ???'s:
• Aluminum trailing arms (74 and later, 74-77 had a ball joint type connection for the rear sway bar, 78 and later I think have a bolt on connection for the sway bar.)
http://www.dietersmotorsports.com/01-2003.htm
Old 05-31-2004, 05:50 AM
Rennch on YouTube
rennch's Avatar
Pat. As usual, thorough and detailed! Thanks!
Michael O'Neal -
Old 05-31-2004, 06:11 AM
Eric Coffey's Avatar
Just to ad/clarify:
• 21mm F torsions never stock, all 911’s had 19mm (18.8mm) front bars.
• 26/7/8 mm R torsions 27mm & 28mm rears never stock, 26mm rear only found stock on 930’s.
• Adjustable Spring Plates 1977-1989
• 22 mm F Swaybar 1986-1989
• 22 mm R Swaybar never stock, 21mm for 1986-1989
• Aluminum front crossmember 1976-1989
• Aluminum trailing arms 1974-1989
• 16 X 7 or 8 cookie cutters (to fit early offset...I DO have spacers) only made in 15x6&7. If you meant Fuchs, most `84-`88's have 16x6&7's. `89's had 16x6&8's stock.
• 16 X 9 cookie cutters (From a 944 maybe?) did not exist. If you meant Fuchs again, 16x9's were only stock (rears) on `86-`89 930’s.
Old 05-31-2004, 11:58 AM
Rennch on YouTube
rennch's Avatar
Thanks for the clarification! Looks like I'm heading the aftermarket route for a lot of this stuff.
mto
Michael O'Neal -
Old 05-31-2004, 01:30 PM
