-   -   What's this type of hose clamp called? (http://forums.pelicanparts.com/porsche-911-technical-forum/165600-whats-type-hose-clamp-called.html)
Jack Olsen 05-31-2004 02:25 PM
Rather than hijack an existing thread, does anyone know of a source for this type of hose clamp? I seem to remember seeing a fastener like this on a clamp where you could adjust the diameter of the stainless band like you might do for a seatbelt, and then cinch it down.
http://forums.pelicanparts.com/uploa...1086038056.jpg
A quick internet search didn't turn anything up other than the snap-release worm-type clamps, which won't do me any good.
Any ideas?
911SCfanatic 05-31-2004 02:30 PM
I think I saw it on the McMaster-Carr website. Check there.
jpachard 05-31-2004 02:58 PM
That looks like a drum clamp. There are similar ones used in exhaust systems too. Burns Stainless carries them. www.burnsstainless.com
I know there are some other sources but can't think of one now.
Cheers, James
TimT 05-31-2004 03:03 PM
v-band clamp... Burns sells them as Jim mentioned, however they have a bolt instead of toggle thingy
then there is the tres cool
wiggins clamp
TimT 05-31-2004 03:14 PM
Also Hoerr racing sells them
Jack Olsen 05-31-2004 03:24 PM
What I need is a fixed size, and a buckle I can close down or release without any tools -- something like the fasteners that hold air cleaner covers together on American cars.
Zeke 05-31-2004 03:27 PM
That is known as a soup can clamp. :D
Seriously, though, could it be in a kitchen (canning supplies) catalogue?
Looks like you found that one in the shower.
TimT 05-31-2004 03:29 PM
Ha!! i knew where I saw that clamp before... on my F250 Powerstroke tow vehicle!!
the air cleaner clamp
hmmmm
Jack Olsen 05-31-2004 04:40 PM
McMaster has one that will work. But at $21 it seems 'too much clamp' for so little soup can. It's the kind of thing home and shop vacuums use to hold cannisters in place, too. I'd like to find the 85 cent solution, ultimately. Otherwise, I'll keep the screwdriver handy for the low-cost stainless hose clamp.
raceman 06-01-2004 12:01 AM
what diameter do you need to clamp?the surplus store for the Los Alamos National Labs has a ton of uber cool techno trinkets like that.Some of the stuff cost us tax payers millions of dollars and it can be yours for pennies.l`ve bought plenty of unobtanium widgets there in the past and they have lots of aerospace quality clamps and fasteners..,let me know what you need as l`m planning a trip up in the next week or two
Jack Olsen 06-01-2004 01:43 AM
Well, the range would be from 7.75-8.0 inches, basically -- outside circumference.
Thanks for looking! I'll hold off on the $21 model. :rolleyes:
EDIT: I originally (and stupidly) typed 'outside diameter.'
RickM 06-01-2004 08:07 AM
What are you clamping? the lips of two halves of a canister or a hose over a pipe?
If two halves of a canister (like a central vac setup) then it's as Tim T describes a V-clamp. The V configuration fits over the lip of each canister half. The realease is an "over center latch". Also how much pressure is being clamped?
911pcars 06-01-2004 10:16 AM
Jack,
Try these guys:
http://www.protex.com/products/framesetup.asp
Have no idea of their cost, but it looks ... not inexpensive. Let us know what you find out. I may have a similar need to secure my crankcase breather tank.
Sherwood
HarryD 06-01-2004 05:27 PM
Jack,
It may also be found in catalogs as a "sanitary fittings". you can also get all kinds of fittings to use with it. They have them here: http://www.mcmaster.com/
Randy Webb 06-02-2004 08:55 PM
Or you can get the web addresses of the vacuum cleaner co.s and others who you know use these clamsp and Email manf. dept. to see where they buy theirs -- they may not answer but I've been surprised who will when asked a question.
earlkeays 06-02-2004 09:19 PM
I think I have one sitting on the shelf in my shop. Its from some old 8 inch galvanized duct work that I dismanteled. Its yours if you want it.
HarryD 06-02-2004 09:58 PM
Jack,
The unit you are showing may be used to clamp the lid on a fiber drum. These folks sell fiber drums and lids (http://www.uline.com/ProductDetail.asp?model=S-9944). I would see if they would be able to source just the clamps for you.
Jack Olsen 06-02-2004 11:57 PM
I need 8-inch circumference, not diameter. I typed that wrong, before. (It's for a soup can.) But if that's what you've got, let me know.
Jack Olsen 06-03-2004 12:00 AM
It's to replace this hose clamp:
http://forums.pelicanparts.com/uploa...1086049270.jpg
HarryD 06-03-2004 12:16 AM
Jack,
What are you trying to do? Replace the worm clamp or the entire assembly?
It looks very much like something on a HVAC system and you should find something using the keyword "duct".
Try looking around Page 171 in the on-line McMaster Carr Catalog. If you can get a hard copy if it somewhere, flip through it looking for duct work, couplings and clamps. You should find what you need.
91C2wrencher 06-03-2004 05:51 AM
Uh-oh! looks like a new generation of the cool-collar on the horizon!
