Should charging volts drop when headlights on?
I recently installed a voltmeter gauge after experiencing some electrical problems and I've noticed that when I turn the headlights on the charging voltage drops from approx 14 to 13.5 volts, and when I turn on the fogs it drops a bit more. Is this normal?
Old 06-01-2004, 06:32 PM
North Coast Cab's Avatar
Yes. As the load increases the voltage tends to drop. As long as you're running at least about 12v you'll be fine. If it gets lower you can harm your alternator.
John
1985.5 944 GTS
Old 06-01-2004, 06:35 PM
kqw kqw is offline
Normal.....
The Fox
Carrera
Old 06-01-2004, 06:39 PM
Thanks for the quick responses! I've just become a nervous-Nelly after having what I think was a bad Optima. The battery wouldn't hold a charge and was replaced for free under warranty (batt. was 6 months old). I installed one of those fused battery disconnects and I use it almost every time I park the car for more than a day. Lately, the tach has been bouncing a tiny bit (pulsing) and this now has me nervous...
Old 06-01-2004, 06:51 PM
Zeke's Avatar
Bouncy tach is because of ?? I missed that one.
Old 06-01-2004, 07:03 PM
I'm off the hook.....
All normal. I disconnect mine if longer than a day or two. Same volts with the lights. Even lower with the air on high.
No, I don't sing. Based there for too long.
Old 06-01-2004, 08:18 PM
