New rear sway bar mounts needed
Besides new rear Pelican Parts HD sway mounts what do I need to replace both sides. I assume griding off the old ones and welding on new but do I also need bushings. Any suggestions for place in Houston to do the work would be appreciated.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 06-01-2004, 12:49 PM
I would rather be driving
jpnovak's Avatar
I can weld them on if you want to take a trip to Austin. If the bushings are deformed or worn looking, replace them.
Old 06-01-2004, 12:57 PM
I always want to take a trip to Austin. Question is how to get the time. I figured I better replace the bushings. Thanks for the offer.
Old 06-01-2004, 01:38 PM
Make Bruins Great Again
Por_sha911's Avatar
I purchased my car with the passenger side welded. The driver's side broke and I had it replaced (Pelican part and installed by my trusted bodyshop genius). I replaced the mount since I've read that the weld will eventually break. I think that you are in the same boat as I am: my time is worth more than the $50 extra to replace the mount.
Note: be sure to get the updated mount (like the one Pelican sells)
Joe
Old 06-01-2004, 09:08 PM
3.2 CAB's Avatar
I made my own mounts, 1/4" thick structural steel, with some creative cutting and grinding to correct shape. Then mig welded them in place. I don't think they will break again. Even the new replacement udated mounts are very thin stamped sheet metal.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 06-02-2004, 04:26 AM
