-   -   Battery Charging Problem - No alternator output - Bad VR? (http://forums.pelicanparts.com/porsche-911-technical-forum/165712-battery-charging-problem-no-alternator-output-bad-vr.html)
katigbr 06-01-2004 11:14 AM
Tried searching the archives but couldn't find any supporting posts.
I purchased a 66 911 last year to "feed" my habit while my 72 "Gretchen" was being rebuilt.
I installed a 2.7RS-clone motor in it over the winter and was running fine until a month or so ago. She started draining the battery, sputter and missing. I then noticed that the alternator light started to glow and got brighter as I drove. I tested the voltage at the battery during idle and at 3000rpm. It never rose above 12.x volts. I assumed it was the alternator.
I've :
1) charged the battery
2) replaced the ground cables at battery and transmission/tub
3) replaced the alternator
The problem still exists.
Can a bad voltage regulator cause a no charging situation?
Any other ideas/suggestions?
gratuitous picture:
http://forums.pelicanparts.com/uploa...1086113482.jpg
Regards,
Rick
ruf-porsche 06-01-2004 11:18 AM
Can a bad voltage regulator cause a no charging situation? YEP
Replace the voltage regulator with a new one, or one that you know is working.
gratuitous picture: WOW NICE CAR.
Jim Sims 06-01-2004 11:24 AM
Check the wiring (driver's side of engine compartment) between the alternator and voltage regulator if you have an external voltage regulator. Jim
katigbr 06-01-2004 02:45 PM
Thanks guys. The VR is on its way from PP. I love the 66. I love it even more with the 2.7 in it.
Rick
