-   -   Reference and speed sensors (http://forums.pelicanparts.com/porsche-911-technical-forum/165716-reference-speed-sensors.html)
kqw 06-01-2004 11:24 AM
I recently replaced my CHT and noticed that the rubber insulation shielding aroung the speed and reference sensors flacked off.
Is this going to cause a problem?????:eek:
ChrisBennet 06-01-2004 11:44 AM
Yep. :D
The failures I've seen of these sensors may actually be a failure of the wire. Those wires sit right over the exhaust and the insulation eventually fails. At least that's what happens here in the northeast. Maybe they would work fine in someplace totally dry. The ones I've seen fail often have heat related symptoms i.e. worked until the motor got hot.
Replacing the original sensors now is much cheaper than getting the car towed or paying for diagnostic time.
-Chris
kqw 06-01-2004 12:20 PM
Thanks Chris....
Can I re-insulate those wires or must I replace the sensors? If replacement is necessary, I am not sure on the correct spacing needed to put the new sensors in.
Rot 911 06-01-2004 12:22 PM
Right off the top of my head I believe the spacing is .08mm, but I would have to double check.
ChrisBennet 06-01-2004 12:41 PM
Oooh, soo close Kurt! If the wind hadn't blown the decimal out of place you would have been right on. (0.8mm)
If the gods have smiled on you, the sensors will slide out of the bracket and you can put the new ones in. (Yeah right!) The adjustment is accomplished with the bracket so if the bracket isn't moved you'll be all set. Otherwise you need to stick/glue an .8mm washer to the end of the old sensor and adjust the bracket that way.
-Chris
kqw 06-01-2004 12:49 PM
If I am correct, the only sensor that needs to be positioned is the speed sensor as the reference sensor will automatically be positioned correctly if the spped sensor is fitted correctly. (right??????)
ChrisBennet 06-01-2004 12:52 PM
From memory (any we all know how bad mine is), it's the lower of the two sensor that you set the gap on. I can't remember if that is the speed or reference sensor.
-Chris
kqw 06-01-2004 12:58 PM
KTL 06-01-2004 01:44 PM
The wire sheathing on our midwest cars suffers the same fate as Chris' NE sheathing. Cooked by the exhaust.
The sensors i've replaced have all needed to be driven out of the bracket. And get busted up pretty good doing so. Just don't damage the bracket. Good luck getting them out without damaging one or the other. Hopefully the one that gets damaged is the one with the bad wiring? But, it'd be wise to replace both since the wire sheathing is most likely bad on both of them. They are unfortunately not cheap. $120 each.
kqw 06-01-2004 04:40 PM
Thanks Kevin...
Are both the Ref. and Speed sensor the same part number? I'm having a heck of a issue locating a parts source for these sensors...
goat 06-01-2004 04:50 PM
Darren at pelican parts faxed me a copy of the specs for these a while ago. I do believe that they had the same number. don't have the paper with me. Maybe he could do the same for you if you give him a call.
Pricey little wires too.
kqw 06-01-2004 04:52 PM
Thanks Tim.....
jc 06-01-2004 05:14 PM
I replaced mine recently so here's a tip:
Before you remove the old one, tie a string to the end of it. That way when you pull it out you can use the string to navigate the new one in place through the hole behind the engine.
Cheers
jc
kqw 06-01-2004 06:27 PM
Gotcha...jc
Jeff Alton 06-01-2004 08:54 PM
Chris is right. It is the lower one that you set the gap on (.8mm) and then the upper one is set automatically.
Cheers, Jeff
Lorenfb 06-02-2004 12:28 AM
The gap on the sensors is not critcal, as long as they are NOT forced too close
to the flywheel. As long as the bracket has not been altered/damaged, the gap
should be O.K. If the boots are cracked or damaged, you can seal and hold the
boots together (and seal out moisture) by filling the boots with RTV silicone.
The key for the sensors is the voltage generated at cranking:
1. reference - > 80-100 millivolts A.C.
2. speed - > 1.00 volts A.C.
rob justice 06-02-2004 01:05 AM
When re-fitting the sensors into the alloy bracket - is it worthwhile smearing anti-seize onto the outside of the sensor? I had one seize and fall to bits when I tried to remove it. Or would the sensor not work correctly if coated?
ChrisBennet 06-02-2004 05:28 AM
I antisieze mine but I haven't had occasion to remove them afterwards so I don't know if it makes a difference. Antisieze does not effect operation.
On the subject of grease/antisieze and it's effect on electrical contacts; I have not found it to hurt anything. On the contrary, it keeps oxygen away from the contacts and slows down corrosion.
-Chris
rob justice 06-02-2004 09:14 AM
Thats cool because the one sensor that was able to be withdrawn was one hell of a state when removed from the bracket.
Mainly because of the cold wet climate over here - if its not coated - its seized.
KTL 06-02-2004 09:31 AM
How about using dielectric grease? Seems that it'd serve the same purpose as antiseize Or would the dielectric grease not last as long?
goat is right. Part #'s are the same for the senders.
kqw 06-02-2004 01:43 PM
In reviewing all my maintenance records, the sensors have never been replaced. I am tracking down a idle problem upon startup.
When cold, the engine stumbles for about 10 seconds and almost dies. After 10 sec's the engine idle is fine and pulls strong. I've cleaned and cleaned the ICV, all contacts, MAF, pulled plug connectors one at a time and noticed a drop in idle, replaced CHT, the idle switch activated and de-activates as usual.
The only thing I can think of is a tank of bad gas, but I ran injector cleaner through a full tank, adjusted the idle up. What's left is the speed and ref. sensors and maybe the ICV is defective.
I sure hate to go to a wrench fo an expensive diagnostic bill.
Thanks guys......
3.2 CAB 06-03-2004 03:30 AM
I replaced both sensors when mine had a no start-no spark problem. It was also having idle issues, hunting, high idle, low idle. I replaced both sensors, ran great, no more idle issues and have not had any more problems. Both of the sensors connectors were toasted and cracked up. I used anti-sieze when I installed the new sensors.
kqw 06-03-2004 06:22 PM
I replaced the O2 sensor and the ICV. ($400.00 geez)
The idle is now rock solid (no fluctuation) I will start the car in the am to see if the low idle issue is solved, however, when I adjusted the idle, I was able to get the idle to have no fluctuation whether I bypased the ICV or not....
Thanks everyone for the tips.....
