banjomike's Avatar
Plastic Polish
I got a pretty good deal on a used good condition rear reflector. It has a few spots where there are light scratches, and it has some signicifant hard water deposits from water running off the car. Does anyone know of a good product to polish this stuf out? Hopefully something that can be found at the local car parts store?
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 08-12-2004, 03:05 PM
Send a message via ICQ to fly944
3M
I have had good luck with 3Ms Palstic Polish.
Old 08-12-2004, 03:07 PM
Mrdi's Avatar
Mcguires has plastic polish in various grits
Mrdi
88 Carrera G50
Old 08-12-2004, 05:15 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Believe it or not but, plastic model car guys use plain old crest toothpaste to polish clear lens plastics. I didn't believe it until I tried it. I'd try it on a bad turn lens first though.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 08-12-2004, 06:15 PM
A company called Novus inc. makes what I believe to be the best. They make a 3 part system, heavy scratch remover, fine scratch and a polish. You can use what ever level you need for your specific needs. Works great!
novuspolish.com
Old 08-13-2004, 05:23 AM
A common approach with Maguires is to start with #17 Plastic cleaner and then onto #10 Plastic polish. Use a 100% cotton towel.
Warren & Ron, may you rest in Peace.
Old 08-13-2004, 05:44 AM
scottb's Avatar
Go to your local aircraft supply store. They have amazing stuff for plastic aircraft windows that removes scratches, haze, etc. If you don't have a local store near you, try these online outlets:
www.chiefaircraft.com
www.aircraftspruce.com
Good luck!
1984 Targa
Old 08-13-2004, 09:33 AM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
wet sand up to 1500 grit sandpaper, then use 3m polishing rub, meguires polish and then #10 polishing compound. It takes time but works damn well, I just had to build an acrylic box for a project in school and after cutting all the pieces we have to polish them up, works damn well.
74 911s neverending story. two feet and a jetta for now.
Old 08-13-2004, 10:56 AM
No flames please. This falls under the Ripley's catagory and its cheap and it works.
BRASSO !
If it doesn't leak, you're out of oil.
If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt.
Screw Flanders....
I'm goin' to Moe's.
Old 08-13-2004, 11:10 AM
