My 1968 Dash has started to crack.....What are my options?
Hi Guys,
I own a 1968 911L....... My dash has started to crack.... I would love to buy a new dash.... Does any one make them? Are there other options for repair (none of that carpet overlay crap) thanx SvK |
SWB owners have one less option which is to buy new OE. i believe the 68 is the only SWB with the 2 piece dash. you can contact justdashes.com for the correct thermal vacuum process (provide your dash as the donor). they only do the sierra grain finish. this will cost you about $450. you can find a good used one - good luck. or you can head down to the industrial part of town and find the hot rod upholstery shop that will recover your dash for $125. the only drawback is that they will have to use a french seam around the gauges to wrap the material. i re-upholstered the horizonatal part myself. http://forums.pelicanparts.com/uploa...1086157678.jpg
How did you go about recovering that dash yourself? I need to do something about my dash, and tweed isn't my style.
If the upholstery shop uses the right material there is no need for the french seam . I just recovered mine with no seam around the gages.
Jim |
Half way down this page you'll see some options for dash rebuilds... http://www.worlduph.com/porsche4.htm
| All times are GMT -8. The time now is 01:01 PM. |
